Road King Wont Start
Old Dec 14, 2020 | 02:51 PM
brakeless's Avatar
brakeless
That year model came with a key fob. Have you looked in all the bags if any for it? Is there a red key light on the dash or speedometer? Is there a Harley dealership near you?
Old Dec 14, 2020 | 03:09 PM
bilpleje d's Avatar
bilpleje d
yes i have looked no key fob .. but there is no red key light when i start it but i can try to take a video clip of it tommorow because its night now in denmark
but if thats the issue is it posibel to buy a empty key fob and then code it have seen some forums where they talks about making a sequens to code a key fob or is it only empty talk??
Old Dec 14, 2020 | 03:17 PM
kel03's Avatar
kel03
My 03 Road King didn't come with a key fob.
Old Dec 14, 2020 | 03:20 PM
brakeless's Avatar
brakeless
From another forum thread:
How to tell if you have a security system.
[size=16px] With the ignition switch in the OFF position, turn the ignition switch ON-off-ON-off-ON[/size]
[size=16px]2. Press the LEFT turn switch 2 TIMES and release[/size]
[size=16px]3. Turn the ignition switch back off[/size]
[size=16px]If you have a security system, you should see the turn signals and indicators flash 2 times.[/size]
[size=16px]The other thing might be to pull off the right side electrical cover (the painted plastic cover right under the seat -- it just pulls off) and look to see if there is a connector for the siren. The connector end is cylindrical about 1/2" in diameter, and would have a dust cap over the end to protect the connections. I don't know for sure if the wiring harness for bikes without the alarm system have the connector anyway, so the presence of the connector may not mean anything. However if it's NOT there, that's a strong indicator that you don't have the alarm system.[/size]
Old Dec 14, 2020 | 04:41 PM
bilpleje d's Avatar
bilpleje d
Okay thank you so much i will try to do .
Old Dec 14, 2020 | 05:20 PM
Screamin beagle's Avatar
Screamin beagle
You said its been sitting for 4 years...have charged the battery? Put in a new battery? Had the current battery load tested?
Old Dec 14, 2020 | 06:12 PM
bilpleje d's Avatar
bilpleje d
yes i have and also tryed to start with start jumper
Old Dec 15, 2020 | 06:24 AM
Magnut1's Avatar
Magnut1
I worked on a couple of 2000/2001 tourings with this issue. Harley used grease for the ignition contacts that got hard and would cause no contact problems. Take the dash off, turn upside down, and remove the ignition switch. Take apart carefully, there are tiny springs in there. Clean the metal contacts and reapply die-electric grease.
Old Dec 15, 2020 | 08:13 AM
cbrenthus's Avatar
cbrenthus
This bike would have had security as an option, so its very possible it didn't have a FOB ever. Since it is cranking, that rules out security and battery issues. Is it carb'ed or fuel injected?
Old Dec 15, 2020 | 11:12 AM
handirifle's Avatar
handirifle
Hope he gets it solved. That sucks to buy a bike from that far away to have unknown issues.
