need a retune?
Old Jan 25, 2021 | 05:36 PM
XJBluto's Avatar
XJBluto
5th Gear
Default need a retune?
I have a 2018 Road Glide Ultra thatI did a stage 1 with Vance and Hines Power Flow Headers and Eliminator 400 mufflers and a screaming eagle breather and Dyno tuned with an OEM harley street tuner . The exhaust is louder than I want . Vance and Hines just released quiet baffles for the mufflers, but I don't want to pay for another Dyno/tune. Can I put the quiet baffles on and not retune?
Thanks in advance.
Old Jan 25, 2021 | 06:08 PM
eaglefan1's Avatar
eaglefan1
I don't know if you need to or not, but tuning is not an area to skip as you know all ready. If its under warranty and the dealer is doing the work, ask them. If you have a indy that you can talk to I would definitely ask them.
Could also ask on the tech forum. Lots of top notch tuners over there.
Old Jan 25, 2021 | 06:12 PM
TriGeezer's Avatar
TriGeezer
Put in the baffles and see how it runs. It won’t blow up.
Old Jan 25, 2021 | 07:02 PM
skydude426's Avatar
skydude426
Old Jan 25, 2021 | 07:16 PM
Weeboy1's Avatar
Weeboy1
The ECM is more than capable of adjusting for minor changes. Changing a baffle style would fall under minor change. You’ll be fine....don’t ask the dealer!
Old Jan 25, 2021 | 09:35 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
If anything the quieter baffle will cork it up a little, which is a lot better than increasing flow substantially , something that would cause a lean condition.
Slide the new baffles in and ride it, look at the plugs in 500 miles, they will tell you if you are lean, rich, or spot on
Old Jan 25, 2021 | 10:09 PM
bdtaylor1979's Avatar
bdtaylor1979
Exactly
Old Jan 26, 2021 | 06:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
You might gain a little more torque by installing the baffles. Torque is good for two up riding.
Old Jan 26, 2021 | 09:27 PM
bklynbob's Avatar
bklynbob
I don’t think it will make much of a difference with the Harley tuner. Wait till you’re off warranty and get a dyno tune with one of the real aftermarket tuners.
harleyrider4300
Jun 29, 2020 05:20 AM
cgmartine
Exhaust System Topics
Jun 9, 2020 06:56 PM
cgmartine
Jun 8, 2020 10:17 PM
shagnasty
Apr 8, 2008 02:26 PM
jfry30
Apr 16, 2007 05:10 PM
