How does taller suspension affect what optimal belt tension should be? For example, my 16 FLHXS came with 12" shocks but I have installed 13" shocks. Do I need to spec to a different tension?
My service manual states each notch in the viewing window represents 1/16" of an inch, I have seen numerous videos on YouTube that claim each notch represents 1/8" inch. What's up with that?
Lastly, who makes the best tension tool? HD or another one?
So let's clarify it - does low profile equal 12" shocks and standard equals 13" shocks?
Yes.
Prior to 2014 the graduations were 1/8". YouTuber's were likely going by that.
easy method without the tool, take your hand and twist the belt, should only twist 45 degrees. I have the tool and done it both ways, both end up at same adjustment.
