Legends suspension
Old Jan 29, 2021 | 06:46 PM
Shaneo1348's Avatar
Shaneo1348
Stage III
Default Legends suspension
So I fu#$%& up putting in my new insets. I forgot to put the top put spring in the tube before I torqued it all together. Now the bottom fork insert drain bolt won't back out. It only spinseven when I hold the other end. Anyone have any tricks up their sleeves????
Old Jan 29, 2021 | 07:19 PM
svarnster's Avatar
svarnster
take the top back apart u may get sprayed but it would allow you to put spring in. I would definitely address the possibly stripped bolt which may need to be drilled out, before putting it back together.. welcome to the forum and good luck.
Old Jan 29, 2021 | 07:56 PM
Shaneo1348's Avatar
Shaneo1348
Stage III
its all new, but I do think the bolt is stripped, as it won't even tighten. And how would a guy get a bit to bite, if the bolt is spinning??? This sounds expensive!
Old Jan 29, 2021 | 08:03 PM
Shaneo1348's Avatar
Shaneo1348
Stage III
ha!!! I got it.... just had to walk away for a few. Thabks again.
Old Jan 30, 2021 | 09:30 AM
decencyxdefied's Avatar
decencyxdefied
Sometimes walking away and regrouping is the best thing. It's better to take time away before you get totally pissed and break ****
Sethc1020
Mar 9, 2020 10:33 AM
crashnasty559
Mar 22, 2016 02:27 AM
shredder22
Dec 7, 2011 12:35 PM
DirtNap
Apr 17, 2010 07:12 PM
chornbe
Mar 14, 2008 07:23 PM
