lift rear wheel
Old Feb 8, 2021 | 06:51 AM
b0fh's Avatar
b0fh
Default lift rear wheel
is there an easy/safe way to do so with a small jack?
like this :
'had' to lift the rear wheel in my FLHTK, grabbed the rearmost part of the frame possible and what went off the ground was the front wheel! crazy as the point I lifted by was way behind the engine. guess all that stuff in the rear is really heavy
is lifting by the swng arm safe? i think not... but just a guess. or do I need to always use the big boy platform jack every time?
Old Feb 8, 2021 | 08:07 AM
RANGER73's Avatar
RANGER73
That jack's to tall and the bike doesn't have the clearance.
Get or make a roller block, or a crank style jack (not the name but I can't think of it) Like a scissor jack
Old Feb 8, 2021 | 08:31 AM
MotoJockey's Avatar
MotoJockey
If you HAVE "a big boy platform jack", I would use it EVERYTIME instead of that jack you're showing. You can change the location of lift point to raise either rear, front, or both.......... SAFELY.
Old Feb 8, 2021 | 08:33 AM
RANGER73's Avatar
RANGER73
Here's a home made one
Old Feb 8, 2021 | 12:37 PM
jake24lt's Avatar
jake24lt
Old Feb 8, 2021 | 01:00 PM
b0fh's Avatar
b0fh
hey no body parts at risk what I meant is just to lift the rear wheel a little so I could spin it to spray stuff on the sprocket (yes I do that, may be I shouldn't but i get decent life out of them so why not), or put the valve in a position that I can air the tire, etc... just small things, I do this with the small jack in the sportster all the time...
to remove a wheel I would never attempt that... for that I have a big platform jack, which weghts a lot and is a PITA to haul around the garage floor.
so the bottom line is that it wont lift easily by just jacking the frame, unless maybe you raise it by a lot (unsafe).
thanks!
Old Feb 8, 2021 | 01:07 PM
NORTY FLATZ's Avatar
NORTY FLATZ
https://www.hardlineproducts.com/pro...or-sportbikes/
twincam10353's Avatar
twincam10353
You don't have to spray anything on the sprocket or belt.
Old Feb 8, 2021 | 01:08 PM
twincam10353
The description says for "chain-driven bikes"
Old Feb 8, 2021 | 01:11 PM
MyFavRk's Avatar
MyFavRk
I have an 8" scissor lift that I use all time . When I want to just lift the rear a little , enough to spin the tire , I keep the bars turned to the left , works just fine . When I'm changing a tire , then I put the bike in a wheel chock , then lift the rear .
