Service / Repair Records
Old Feb 20, 2021 | 07:29 AM
Wizard46's Avatar
Wizard46
Default Service / Repair Records
Does Harley maintain repair records on bikes that is available to new owners. Problem, I have a 2002 twin Cam 88, I know the cams, chains and tensioners was replaced. I know this was Harley shop done but not where and what was installed. Any way to find out, previous owner not available.
Old Feb 20, 2021 | 07:38 AM
Jackie Paper's Avatar
Jackie Paper
When I got my 04, the local dealer printed off a 3/4 inch book on it. It did have the extended warranties from Harley and the two local dealers however.
A 2002 probably falls in my catagory of they should be replaced even if not worn, just to heat harding from 10 years or more. I am referring to shoes, inspection oil pressure before tear down, then measure oil pump for wear, new inner cam bearings, shoes, and gaskets.
Don't fall for so called silly not true upgrades
They are not a regular schedule maintenance item. How do you know they were replaced.
Mine are original. But I'm local now and actually no longer ride right now.
Old Feb 20, 2021 | 07:48 AM
pgrchaplain's Avatar
pgrchaplain
Stop by the Dealer Service Dept. with your VIN.
Old Feb 20, 2021 | 08:28 AM
GalvTexGuy's Avatar
GalvTexGuy
From what I know, H-D does not have a nationwide database to access repairs/upgrades performed by dealers.
Old Feb 20, 2021 | 08:31 AM
Spartanden's Avatar
Spartanden
One thing I do is record all service, repair, maintenance, accessories added into a 3 ring binder. When I sell the bike, this notebook goes with it. The new owner will have a detailed list of what was done on the bike. I know this does not help you or answer your question, but I strongly recommend that everyone does this. It does show proof of maintaining your bike, but great reference for brakes, tires, etc.
Old Feb 20, 2021 | 09:34 AM
svarnster's Avatar
svarnster
pop the cam cover off and look. see what is in there. welcome to the forum
Old Feb 20, 2021 | 09:59 AM
smitty901's Avatar
smitty901
Dealers are not really open to giving out detailed records as they once would do. Has to do with privacy concerns , time cost. If the dealer is one that knows you well you are more likely to get some where. Yes the records are there. They will help when a bike is wrecked with the adjuster. Records from the dealer hold a lot more value than yours do.
Old Feb 20, 2021 | 10:09 AM
GOV5's Avatar
GOV5
I do something similar to what you do. I put all my receipts, folded, into my Owner's manual which is kept in my right saddlebag. That goes with the bike when sold or traded. I think just keeping records and having them available to prospective buyers helps get your bike sold more easily. The new owner will know what he's buying and how it's been maintained.
Old Feb 20, 2021 | 10:13 AM
freakfxr's Avatar
freakfxr
I've had dealers send me all the service info on a specific bike once I owned it, however I had to figure out which dealer the service was performed at in order to get the info.
Old Feb 20, 2021 | 10:18 AM
GalvTexGuy's Avatar
GalvTexGuy
That's the key. You have to know which dealer(s) performed the work.
