Stuck Oil Filter
Old Mar 4, 2021 | 03:22 PM
  #31
gravnov's Avatar
gravnov
This little rasp made my day during my last filter-change.
Old Mar 4, 2021 | 03:45 PM
  #32
98glider's Avatar
98glider
Probably a Harley mechanic put it on and Over torqued it usually you should warm the bike up first get all the oil’s going and sometimes it will warm up the gasket I’ve tried channel locks when the wrench wouldn’t work or I should say spanner wrench then if those two don’t work I ran into the screwdriver to do the trick sometimes if you go up and down on the oil filter will break that little seal from the rubber gasket that might help good luck
Old Mar 4, 2021 | 09:42 PM
  #33
br4n0's Avatar
br4n0
4th Gear
Well, I can’t find a way to edit my original post, so I guess I’ll reply. First off, thanks to everyone for taking the time to reply. I read each message and took all your suggestions into consideration.
i decided against buying another wrench, as the filter is so crumpled from me torquing on it, nothing will fit at this point.
and I mean I was cranking on that thing with the strap wrench. So much so that I was afraid of breaking or bending other parts of the bike.
The workspace is too tight to get channel locks in there. In fact, I tried the hammer and chisel approach, but again space is so limited I only managed to dig into a very small area on the top.
i did all of this after warming the bike up for a few minutes.
so I guess I’m left with just shredding that filter to bits and pulling the remains off the main body with pliers, or give up and take it to a pro. Any last words of wisdom? Thanks again in advance.
Old Mar 4, 2021 | 09:47 PM
  #34
lawrosa's Avatar
lawrosa
Thats why I use k and n filters.. bigger filter and has the bolt on the end
Old Mar 4, 2021 | 11:11 PM
  #35
MotoJockey's Avatar
MotoJockey
WP50's suggestion (post #29) of removing the voltage regulator to gain a clearer shot at that filter would be my next move. Get yourself some work space and try some bigger tools.
Old Mar 4, 2021 | 11:39 PM
  #36
F150HD's Avatar
F150HD
Originally Posted by br4n0
...so I guess I’m left with just shredding that filter to bits and pulling the remains off the main body with pliers, or give up and take it to a pro. Any last words of wisdom? Thanks again in advance.
JMO, but maybe best to walk away for a day before you FUBAR the bike trying to remove it. We've all been there.
I had a dealer do an oil change once years back on a tour....once home I couldn't get the filter off to save my life. Once my current HD filter stock runs out I think I'm going to shift to K&N w/ the nut on the end. Thats the plan anyway.
Maybe post a pic. Not that it will help, but maybe it will.
Old Mar 5, 2021 | 12:03 AM
  #37
Ragtop's Avatar
Ragtop
Tear that sucker off piece by piece if you have to!
If you try the screwdriver route, use a fat one and drive it through both sides of the filter, making sure
there is room to spin it with the driver installed. I had one that took my huge channel locks to get off
If you have to tear the outer can off, then you can get inside and find something better to grip onto.
Good luck
Old Mar 5, 2021 | 01:39 AM
  #38
stuart1270's Avatar
stuart1270
If the filter was that tight the k&n filter with the nut could not save you those nuts are BS I've had them shear off the body of the filter more than once.
Old Mar 5, 2021 | 05:57 AM
  #39
Notgrownup's Avatar
Notgrownup
I had to drive the screw driver in about 4 times to get it moved in very small increments and finally it gave way. Cleaned the whole area with brake cleaner. If you do it right , the next time a strap wrench or cup type remover gets it off easily. 107000 miles on my old FLHTC and never a problem until I bought this Tri Glide
Old Mar 5, 2021 | 07:18 AM
  #40
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Remove some things to give yourself the necessary room.
A chisel is a cutting tool, don’t cut into the mount while cutting into the filter. Sometimes switching to a dull chisel or a punch after cutting a good notch with a sharp chisel works better.
With things removed for access, you may be able to get in there with a truly large set of channel locks. Similar caution about not tearing up the mount.
