Clutch lever problems
Old Mar 3, 2021 | 06:47 PM
Andrew Long's Avatar
Andrew Long
Stage I
Default Clutch lever problems
I have a 2014 street glide special with a Barnett scorpion clutch in it had to do a rebuild on it while installing noticed that clutch lever locks up on bleeder screw is closed with no action to the push rod clutch does not move. Took slave cylinder off pulled it slave cylinder moves. What is going on why is it not pushing pushrod is smooth and not binding
need some help here! Stumped
Old Mar 4, 2021 | 01:18 AM
Dano523's Avatar
Dano523
Problem on some of the after market clutches with the stock Hydro system, is that there is no adjustment on the basket side for the push rod, and some times, you have to make a longer push rod isntead. So my guess, is the slave is already all the way out, but the clutch push rod is not long enough, and the reason that the slave is maxed outwards before the clutch pressure plate is being pushed out.
Hence guessing when you installed the oil slinger assembly, it's tight to the front side of the trans shaft, instead of sticking way back out instead.
https://partsfinder.onlinemicrofiche...EET%20GLIDE%20[KB]%20CLUTCH%20ASSEMBLY
Also, double check, since you may have left oem plates in the basket, which gets removed when you are installing a extra plate clutch.
If you left the last two oem plates in, it would explain why the pressure plate is father off the basket and could be causing some of the problems.
Skip to 2:30,
HDJIM1158
Oct 21, 2015 08:19 AM
LucyOnBlack
May 27, 2013 10:58 PM
gscrsigs
Jul 7, 2009 03:07 PM
dragbar
May 2, 2008 08:38 AM
Bigg
Panhead
Sep 12, 2007 12:36 PM
