Vibrations
Old Jun 6, 2021 | 10:20 AM
Cage-Free's Avatar
Cage-Free
It really sounds like you ought to get your tire balance checked. If you lost a tire weight accidentally, that will cause vibration at higher speed.
Old Jun 6, 2021 | 03:20 PM
DanHappy's Avatar
DanHappy
Did you check the front neck bearings and / or the neck for proper fall back test and tightness?
Old Jun 6, 2021 | 03:54 PM
MyFavRk's Avatar
MyFavRk
Check the top stabilizer bar , if you can twist it with your fingers , replace it , it should be quite stiff .
Have you checked inside the fairing yet ? Bar riser bolts , fairing mounts , radio , gauges etc .
Old Jun 6, 2021 | 08:35 PM
hamah's Avatar
hamah
^^^this. Check Steering Head bearings for tight/loose adjustment by doing a fall away test. Also check for clunking in the front end but grabbing the forks near the brake rotors and giving a good tug looking for looseness.
Old Jun 7, 2021 | 11:46 AM
bundy43's Avatar
bundy43
you said it smooths out with a little throttle, does it still vibrate while riding.
kschulz1960
May 11, 2011 12:14 PM
lou1
Nov 16, 2010 04:10 PM
BlueThunder3212
Exhaust System Topics
Oct 27, 2009 11:05 AM
keltics mc
Oct 3, 2007 06:55 PM
vernh59
Jun 21, 2006 01:30 PM
