Installing Chubby bars
Old Aug 2, 2007 | 07:04 PM
chappy_2336's Avatar
chappy_2336
Default RE: Installing Chubby bars
PRC8779: What, are you trying to charge me a case of beer???
Old Aug 2, 2007 | 11:47 PM
gregm's Avatar
gregm
I wanted more pull back on my 05 EGC and I was going to have the 575s installed,but declined when I sat on one that had them installed. I like my hands close to being inline withmy shoulders when I grab the handle bars, but the 575s are 2" wider than the stock HD bars and I found myself trying to put my hands on the switch area of the grips. Just MHO.
Gregm
Old Aug 3, 2007 | 01:38 PM
Manish_Hawg's Avatar
Manish_Hawg
If you have a digital camera take pictures.
Old Aug 3, 2007 | 04:29 PM
kurtlange's Avatar
kurtlange
ORIGINAL: BadX
remember the pin locations? I just spliced the wires and soldered them back together and shrink tubed the connections.
waaayyy too much work. i made a diagram, undid the wires, ran them thru the bars and reinstalled them in the clips all in 30 minutes.
Old Aug 3, 2007 | 04:39 PM
Puttnutt24's Avatar
Puttnutt24
I don't care what anyone tell's you here (sorry guy's) but it's not a good idea to use the two piece handlebar clamps when installing the 575's (or any other Wild 1) Use a good one piece handle bar clamp and also change out the stock rubber handlebar bushings with harley's polyurathane bushings. This will prevent them from sagging later on. Just my take, Putt
Old Aug 15, 2007 | 11:54 PM
chappy_2336
Finally got all the parts in, did the install this evening with no problems. I went with 4" over cables, everything fitgreat, no complaints on the length. I used the new harley 1 piece clamp, fit like a glove. I did pull the radio, only took about 5 mins in and out, only 4 screws. Ignition switch was simple. Internal wiring took maybe 30 mins, no fitment issues. Probably would have sucked if I didnt have true duals, simply removed bolts for muffler hanger and tranny mount and easy access to the side of tranny and clutch cable. Bars look great and feel good, it was too late for a test ride, will give feedback on that tommorrow with some pics.
Old Dec 15, 2007 | 01:13 AM
07RoadGlide's Avatar
07RoadGlide
ORIGINAL: chappy_2336
Probably so. Damn retirees!
Bertk
2014-2024 Touring Models
206
Jun 9, 2020 05:14 PM
Baldfox157
Jan 18, 2016 10:00 AM
Rampant
Aug 11, 2013 02:59 PM
Pussboy
Apr 25, 2012 06:58 AM
eazyrider
Sep 14, 2009 03:13 PM
