1" up 2" back?
Old Apr 24, 2012 | 10:33 PM
Pussboy's Avatar
Pussboy
Default 1" up 2" back?
My buddy needs to raise his bars up and back some. He has a '12 ultra. Any suggestions on how to accomplish this with stock bars? Any recommended replacement bars?
Thanks in advance, Scott
Old Apr 24, 2012 | 10:43 PM
mkguitar's Avatar
mkguitar
1st try is to remove ign switch and lower dash panel ( check youtube for tutorial on the switch DO NOT use a screwdriver, make the tool).
thick towel on tank
loosen the 2 bolts on the clamps which are now accessible.
Rotate the bars to what seems to be the right position- tighten clamps.
put it all together.
next step involves changing bars- at this point the wiring seems to trip up many riders ( post after post of "now it won't start")
Try the easy first.
mike
Old Apr 25, 2012 | 12:12 AM
0ldhippie's Avatar
0ldhippie
I am also wanting to bring the bars back 3"-5" and up maybe 1"-2". Already adjusted as good as can be. Harley has some "pull backs" but they are only 2" back and $. Anybody got something that works?
Old Apr 25, 2012 | 03:23 AM
jjnoble's Avatar
jjnoble
For some reason they don't make a lot of bars that come back closer to you. Good luck with that.
Old Apr 25, 2012 | 06:07 AM
Junior in NE's Avatar
Junior in NE
I put wild one 575's on mine, 2" up and 2" back. Works great for me.
Old Apr 25, 2012 | 06:13 AM
jjnoble's Avatar
jjnoble
I'd like to have some 14" bars, but I don't want them pushed up against the windshield. I want them pulled back so I can lean against the backrest. Having some custom made is about the only option.
I have the 575's right now, at the time it seemed like 2 up and 2 back would work for me, but it turns out that is not so.
Old Apr 25, 2012 | 06:44 AM
weride7/7's Avatar
weride7/7
I tried several bars, all failed. Trying to figure out how to add pic.
Old Apr 25, 2012 | 06:57 AM
weride7/7's Avatar
weride7/7
I tried Santee, 575, and pullbacks, all failed. Had my custom shop add in 4" of s.s to stock bars...PASS.. The wires were tight so I lengthened them .
Old Apr 25, 2012 | 06:58 AM
KeeBee's Avatar
KeeBee
I have 12" monkey bars even though they are pushed up against the windshield I can still lean back far enough for a backrest. I am 5'11" average arms but if you are shorter or have short arms it will be a different story.
Runcy12
11
Sep 4, 2018 11:54 AM
stevedrum4578
Feb 24, 2012 01:49 PM
eazyrider
Sep 14, 2009 03:13 PM
SLP24
Mar 11, 2009 06:34 PM
flpops
Sep 5, 2007 03:24 PM
