Switch Housing: What's this part???
Old Mar 23, 2021 | 01:49 PM
xk49's Avatar
xk49
Default Switch Housing: What's this part???
2016 Road Glide. Opened up my clutch side switch housing(the housing with all the electrical stuff, horn, turn signals etc.) and this little part fell out. I have no idea where it goes back into. Can someone tell where this part is supposed to go?
Old Mar 23, 2021 | 03:15 PM
MURPHCC1's Avatar
MURPHCC1
Part # 15?
https://partsfinder.onlinemicrofiche...VER%20ASSEMBLY
Old Mar 23, 2021 | 04:56 PM
xk49's Avatar
xk49
Sorry, should be clearer in my post. It's the switch housing that has the horn, signals, etc., the electronic stuff.
Old Mar 23, 2021 | 11:19 PM
Musician's Avatar
Musician
I can't really tell from the angle of the picture, but the only thing that should be in there that's around that size is the clutch interlock button. That thing that won't let you start your bike unless the clutch is disengaged. If it isn't that then I have no idea. Only manual I have is for my '08 FLHT, but most the switch housings are quite similar.
Old Mar 24, 2021 | 09:17 AM
xk49's Avatar
xk49
I'll take a look at where the clutch housing mates to the electrical housing and see if that's where it goes. Funny it should just fall out when dissembled.
Old Mar 24, 2021 | 03:21 PM
barneyboy's Avatar
barneyboy
Are you the original owner? I've run across a variety of unidentifiable non-OE parts that previous owners have used to fix something that was broken. Some are well thought out and long lasting, some not so much.
Old Mar 24, 2021 | 04:21 PM
xk49's Avatar
xk49
I put everything back together without the little part and everything appears to work. I guess it's off to the "Unknown Parts" box. Someday I'm going to need a bigger box.
Old Mar 24, 2021 | 04:48 PM
Ssitruc's Avatar
Ssitruc
Does it start in gear, with the clutch pulled in?
Old Mar 25, 2021 | 10:16 AM
btsom's Avatar
btsom
Try this, #25 or 26
Old Mar 25, 2021 | 05:56 PM
jimglassford's Avatar
jimglassford
Originally Posted by btsom
The diagram does not have a 25 or 26.
