Power vision help
one of several available.see #2 above
im pretty sure they can access you pv remotely and trouble shoot it
ive always had the hits screen active until finished the run and then touched exit-export learned and apply to a tune slot. Then you have to go back to load tune and flash your new tune from the tune slot to the ecm. Or re-enable auto tune and continue auto tuning on your previous tune.
also remember not to turn key off until prompted. Use on/off switch to kill bike.
from what you describe something sounds off with your pv.
also make sure your pv is up to date.
Where do you have the PowerVision tuner while you are tuning....??
Could you have it in a pocket, or someplace where something is inadvertently touching the screen and changing the screens on you?
When you are done with your auto tune, and you are back at the Auto tune session screen (with the export learned button shown below) what does it say at the top? Is it labeled with an auto tune session number?
Look at the bottom line, just above the buttons where it says "Learned VE:xx cells.avg xx%. max xx%" In the example below it shows 86 cells, 12% average and 15% max
That will tell you what the auto tune session accomplished.
You could also hit the "Datalog" button on that screen, and it should go back to the green screen... any tuned cells will have numbers in them and color coded to the number of hits that cell received..
If you are showing the number of cells learned with max/avg percentage of change, and when you go back to the datalog form the screen shown below and the cells are filled with numbers, many of them red in color, you have completed your auto tune session and somehow just hit the screen and it switched back to the red screen shown below by accident...
Hope that all made sense...
This is the auto tune session screen:
This is the Green screen showing the cells with hits... red = most hits, orange = some hits, yellow = few hits:
