2015 FLHTK right side dash harness plug
Old Oct 16, 2024 | 06:15 PM
EvilFuzz's Avatar
EvilFuzz
Did you ever figure out what this plug was for? I was wondering the same thing. I removed the dummy slot and replaced it with an accessory switch that I used for my garage door opener. I just shoved that unused harness back into the fairing, never knowing what it could be used for.
Old Oct 17, 2024 | 05:31 AM
jake24lt's Avatar
jake24lt
When you buy the switch pods, it comes with a wire harness. There is a connector under the seat or the right side cover, forgot which. There is a connector there you plug the harness in. This will give you one lower power pig tail, one with a connector on it, and one high-power with a relay you hook up to the battery. You are not supposed to run anything directly off the switches on the dash. Their function is to liven up the harness that came with the kit.
tda69
May 2, 2021 08:05 PM
fiddypal
Milwaukee Eight (M8)
17
May 29, 2017 07:47 AM
Bigg Lou
May 9, 2014 02:18 PM
tooloudman
Aug 28, 2012 02:48 PM
B dog
Mar 30, 2007 11:08 PM
