Is this a problem
Old Apr 11, 2021 | 05:11 PM
Hawg Runner's Avatar
Hawg Runner
Default Is this a problem
Changed the clutch slave cylinder on a 16 street glide and while doing so the clutch push rod was pulled out also, pushed it back in but continue to have problems getting enough clutch to not have it roll and have hard time finding neutral, have not tried the syringe method yet, but did it the old fashion way, plus using a mighty vac, went through 2 bottles of fluid and still cannot get enough pull to disengage the clutch properly when running. Yes same bike post on the muller clutch slave,16 twin cam street glide special. Would like to get a speed bleeder for it, but don't know which one. Thanks.
Old Apr 11, 2021 | 06:00 PM
702's Avatar
702
The pushrod being pulled out is not an issue. Any chance you boogered up the o-ring on the piston when you installed it?
Old Apr 12, 2021 | 01:08 AM
Hawg Runner
Took apart the piston to make sure it was okay.
Hawg Runner
Apr 11, 2021 06:15 PM
Txride
May 23, 2020 02:33 PM
not a sock
May 1, 2020 08:50 PM
b2000s81
May 28, 2015 02:02 PM
Muld3r
Jun 1, 2013 12:03 AM
