Engine noise 09 electra glide 96 cubic inch
Old May 4, 2021 | 02:10 AM
HDFORM's Avatar
HDFORM
Originally Posted by KingJames252
thanks for that info! I have the darkhorse man o war compensator with about a 1000 miles on it now. I pulled the primary and checked it again also
i heard about that Comp and Baker, Both required Modification's so I was told, so I just installed the upgraded Screaming Eagle comp, it solved all the rattles. Check your primary Chain Tensioner also.
My Auto chain Tensioner Ratcheted two notches Twice , From Riding the twist's hard throttle on and Decell Braking. so I installed a Screaming Eagle manual Chain Tensioner ,with new chain .
With the new comp Chain and Tensioner there Is no noise no more problems.
Noises are a bitch ,but it is a Harley.
Old May 4, 2021 | 05:39 AM
pingman68's Avatar
pingman68
To me, it does sound like something vibrating off the exhaust pipes...
Old May 4, 2021 | 06:08 AM
Weeboy1's Avatar
Weeboy1
I’d recheck the heat shield clamps. They can develop flat spots and if not back in same position can rattle. Or could be a clamps trailing end touching metal.
try taking all the heat shields off and see if the rattle remains.
Old May 4, 2021 | 09:15 AM
NELS's Avatar
NELS
Buddy's bike had covers under the spark plugs that made a noise like that. Just throwing it out there
Quiet Thunder
Jul 14, 2015 05:55 PM
Tommy Hager
Engine Mechanical Topics
Jun 7, 2013 02:43 PM
sifularson
Screamin Eagle CVO Models
21
Apr 3, 2012 07:49 PM
Bigbob88
Dec 10, 2008 09:54 PM
donjan
Sep 19, 2005 12:14 PM
