Engine stabilizer bar
Old May 9, 2021 | 04:15 AM
Mongo1958's Avatar
Mongo1958
Default Engine stabilizer bar
Hi,
has anyone replaced the engine stabilizer bar just above the front rocker cover?
My 2009 FLHTCU Ultra Classic has an engine stabilizer bar that squeaks and is jammed and no longer pivots on the spherical bearings.
I added a drop of oil and used pliers to break it free. Now it can pivot, sort of. It still gets jammed intermittently.
Old May 9, 2021 | 06:36 AM
MyFavRk's Avatar
MyFavRk
I replaced mine last year , was so loose , you could twist it easily with two fingers , it should be somewhat stiff and hard to move by hand . If yours is causing you issues , I would change it , cheap enough .
Old May 9, 2021 | 09:41 AM
Ron D 33's Avatar
Ron D 33
It's also easier to do with the bike straight up and not on the stand. The holes can be a pain to get lined up if you don't do it that way.
Old May 9, 2021 | 10:16 AM
skydude426's Avatar
skydude426
If it’s sticking that bad, replace it.
whynot2
EVO
Oct 11, 2019 08:16 AM
Whitetrash1
Jun 26, 2019 07:36 AM
Leevi
Nov 23, 2016 04:04 PM
Adrian Thompson
Oct 29, 2012 05:13 PM
nhbiker1961
Sep 30, 2009 11:08 AM
