Rear sprocket bearings
Old May 28, 2021 | 09:23 AM
hattitude's Avatar
hattitude
Originally Posted by LQQK_OUT
Would a wheel even fit inside the hydraulic press that the average person would have at home?
There's the rub...
I looked at getting a hydraulic press to do my wheel/pulley bearings a year ago... I could also use it for other things while working on my bikes/cars...
I only did a cursory check, as time was a bit of an issue. The hydraulic presses I found, that were large enough to fit a wheel/tire for wheel bearing install/removal, were too big for my space, and made a considerable jump in price from the usual suspects. Most of the usual suspects wouldn't fit a wheel/tire between the main supports..
I had a dealer do it for me... I was surprised, well actually shocked... the tech did a good job and it was at a reasonable cost...
I put the press verus wheel bearing tool on the back burner for further research...
Old May 28, 2021 | 10:27 AM
LQQK_OUT's Avatar
LQQK_OUT
I have an older Harbor Freight 12 Ton H-Frame Floor Shop Press (item #533497), similar to this one. One of the complaints of the Harbor Freight press is that there is a lot of play in the unit. If you read through the comments in the reviews, these issues can be fixed using washers, different bolts, foam tape, etc. I've made some of the changes and the press is fine for what I need it for. Plus, it's a convenient tool to have.
For wheel bearings, I have the tool from George's Garage. I know many people favor the tool from Pit Posse (VT102) due to the more affordable price. I like the tools from George's Garage. Made in the USA, great warranty and his tools are made from heat treated steel, which may be stronger than the tools from other vendors. I thought the strength was important due to the small lip on the puller shafts of the wheel bearing tool.
One other piece of information. The press plates that come with the Harbor Freight press are garbage. Do yourself a favor and pickup good plates. I purchased my plates from Swag Offroad.
Old May 28, 2021 | 06:27 PM
hattitude's Avatar
hattitude
Thanks for that info, but I like tools... I usually never let an excuse to buy a tool pass me by....
As such, I like to buy quality tools, even if I only plan to use it once... I with few exceptions, I rarely buy tools from Harbor Freight, unless aI'm considering it a throw away...
I was looking at something like this one...
https://www.summitracing.com/parts/oes-25087?rrec=true
But it was too big, for my little shop...
ghoulardo
2014-2024 Touring Models
27
Oct 18, 2020 06:43 AM
FATKEVIN
Mar 26, 2018 09:25 PM
big ears
Apr 30, 2012 06:43 PM
trackadaptor
Apr 11, 2011 07:07 PM
BuckWhalen
Wheels/Tires
May 21, 2010 05:46 AM
