Big bore
Old May 29, 2021 | 12:37 PM
Bafflingbs's Avatar
Bafflingbs
Originally Posted by jdcinak
Can I use a larger stroke flywheels ?
Cheaper, and better, to just get a crate engine. Though, I did a 95” with Andrews tw26 cams, and it ripped! I think I ended up with 88hp/105tq
Old May 29, 2021 | 04:27 PM
jdcinak's Avatar
jdcinak
Originally Posted by Neggy ZRXOA 5248
just put a big bore/big stroke S&S engine in it
88 to 95 is easy, everything else is going to require a lot of parts and lots of machine work
I’ve looked and they don’t have anything available plus they want 10k. I already have a 103 pistons heads and jugs
Old May 29, 2021 | 05:18 PM
roussfam's Avatar
roussfam
The heads are the same as what you have now, but 06 and up castings flow better. So better heads, especially with a .030 head gasket.
88 and 96 jugs are the same, it's the stroke that changes to make it a 96.
95 and 103 jugs are the same, it's the stroke that makes it a 103.
103 and 95 pistons are different though, wrist pin location. So you can use your 103/95 jugs with 95 pistons only on your 88 to turn it into a 95, 103 pistons won't work unless you change the stroke.
Your only option is to use your 103/95 jugs and buy a set of 95 pistons BUT if your buying a set of pistons you can always buy 98 pistons, have your 88 bored to 98 and sell your 103 jugs and pistons to offset the cost
Hope this all makes sense
Jim
Old May 29, 2021 | 05:44 PM
jdcinak's Avatar
jdcinak
Jim
Thanks for breaking it down Jim. Would changing the stroke be a costly endeavor?
If I opt for boring my 88 to 98 should I use the heads that came with the 103? I should add that they are SE heads if that makes a difference
Old May 29, 2021 | 06:18 PM
roussfam's Avatar
roussfam
Cost is relative, in my world I find it pricey BUT if you were going to go for the longer stroke then I would highly recommend getting a trued and welded crank.
Those heads will fit on all Twin Cams, but some years require a manifold change (newer to older/ older to newer swap) Stock 06+ castings, flow better, and seeing how yours are Screaming Eagle, even better yet.
You could build a pretty strong 98"
We have a lot of experienced engine builders on the Forum. Someone will be along soon with a lot more knowledge. Good Luck
Jim
Old May 29, 2021 | 06:27 PM
jdcinak's Avatar
jdcinak
Jim
Thanks
Old May 30, 2021 | 08:14 AM
rigidthumper's Avatar
rigidthumper
If you want it to be a 103, you need a 4.375 stroke flywheel set made for 99-06 TCA engines, so it's compatible with your drive train.
Expense is parts + fluids + tuner and time, easily a couple grand at a minimum- much more if you're paying someone to do the work. Most places charge between 10-15 hours to replace flywheels, so with the cost of new flywheels, you could easily spend $4k
Old May 30, 2021 | 10:15 AM
jdcinak's Avatar
jdcinak
Does anyone make a flywheel in this stroke or is it a custom piece?
Old May 30, 2021 | 09:36 PM
rigidthumper
HD, DarkHorse, S&S, others.
Old May 30, 2021 | 09:58 PM
jdcinak's Avatar
jdcinak
Thanks for the info guys. Can anyone recommend a cam for this build?
