primary adjuster
Old Jun 9, 2021 | 12:58 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
To answer the original question , the interval for manual adjustments to the primary chain is 5K miles.
Old Jun 9, 2021 | 01:10 PM
Redbeard719's Avatar
Redbeard719
The Baker Attitude Adjuster didn't work well for me. The updated OEM version is serving me well now.
Attachment 613968
Old Jun 9, 2021 | 01:14 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by TriGeezer
Although I went through several SE compensators on my stage 2 ‘12 TriGlide until I installed a Baker. I never had an issue with the OEM adjuster in 45,000 miles.
BTW, I wouldn’t want to have to pull the outer primary cover every 5K miles just to adjust the adjuster. If there was an and judgment window, I might have considered that.
Old Jun 9, 2021 | 05:43 PM
Notgrownup's Avatar
Notgrownup
Ain’t no way I would want to open the primary every 5k miles. That’s why I have the Hayden
Old Jun 9, 2021 | 06:22 PM
Jackie Paper's Avatar
Jackie Paper
Mine has a OEM manual adjuster. It has 50,000 miles on it. It took around 30,000 to finally groove the outer links into the tensioner. Once there, chain was on the rollers on tensioner which of course rolled on it and wear ceased.
My chain does have some typical uneven wear, so chain slack varies as you check it in various increments.
I bumped it up one notch. This does make one area at 3/8 play which is a little tight. The looses area is about 5/8.
Works for me. One click removes about 1/4 chain slop.
I personally think the auto adjuster was just something Harley did to appease buyers and was not necessary. The maintenance call out was not necessary and was the biggest problem.
Those who beat their bikes probably disagree but the auto adjuster causes problems for them too. Beating a Harley causes crazy uneven chain wear. The auto sets on the loose area and is too tight in others.
Rodent66
May 26, 2021 09:06 PM
P51Driver
Jul 4, 2018 12:45 AM
timsmcm
Dec 30, 2013 08:34 AM
eravo
Jun 28, 2007 08:43 PM
gtrman
May 25, 2006 06:27 PM
