thunder max ?
Old Aug 5, 2007 | 08:03 AM
DAVETHEBUILDER's Avatar
DAVETHEBUILDER
Default thunder max ?
Every sencemy builderinstalled my thundrmax Ive had a dead spot from 2500 to3000 rpm. Yesterday he put in different map because he couldnt get rid of the flat spot. Now the bike is missin, jumpinand poppin, my question is how much will the auto tune fix and how long will it take, or do you have to be real close before the auto tune will do any good ( The bike runs great now at wot)
Old Aug 5, 2007 | 10:27 AM
DAVETHEBUILDER
Default RE: thunder max ?
I guess all the thundermax guys gone riden
Old Aug 5, 2007 | 11:10 AM
notorious's Avatar
notorious
You should try to be as close to a match as possible. The learned curve will depend upon the variables of the chosen mapand the actual build of the bike.I notice you have quite an agressive build so search and go from there. Now you can reload your last map if you saved the auto tune settings and improve upon it, that is if you saved all of your parameters.
Old Aug 5, 2007 | 12:47 PM
glens's Avatar
glens
As I understand it, the BLM has hard limits. You'll just have to step your way out of the rough spots manually to get a "floating" BLM for the troubled areas too.
Old Aug 5, 2007 | 01:38 PM
PhilM's Avatar
PhilM
ORIGINAL: glens
Block Learn Multiplier is the strategy used by DTT in the TCFI systems, not the TMax. The DTT BLM's are configure to tune +/- 10%, by default. Perhaps some of the TMax guys can elaborate more on how the TMax does it.
"It was my experience" that if I fould a flat spot (rich/lean/whatever), I would intentionally run the bike in that range and "force the sytem to learn" in that "problem" area. THe DTT learns pretty quick, so it's a fairly simply process. In fact, all the systems I've install or helped with are usually tuned in pretty darn good in an hour or two. Admittedlt, they will continue to learn for a long time, but we can get them pretty close in a fairly short time frame.
Old Aug 5, 2007 | 01:49 PM
whateva's Avatar
whateva
The Tmax is defaulted to only adjust the offsets 5% per session but you can change that. It is defaulted to make adjustments overall at 10% but you can change it to as much as 50%. Click confure > closed loop module settings,,, and there it is.
My bike ran great right from the install but the mileage was only 33 mpg. Mostly riding 30 or so miles per day to and from work. Went on a 350 mile ride last weekend and during the trip, notice I was getting a lot more miles. Filled up twice since then and now getting 38. It doesnt learn quickly. You have to ride it a bit. If it were me,I would put the old map in there, set it to adjust 15% per session, 30% overall (since you have that particular build)and hit the road for a couple of hundred miles, stopping every 50 miles or so and then restart so that it can adjust..
Maybe some of the experts would disagree but thats what I would do first.
Old Aug 5, 2007 | 03:00 PM
glens's Avatar
glens
Yeah, sorry about bringing up the BLM tables. I open several tabs at once (on dialup, so I can get right to reading) and somehow must've thought I was in a DTT thread.
Old Aug 5, 2007 | 03:35 PM
Plow64's Avatar
Plow64
Is the base map you're using a close match to your engine setup? I ask becauseI've had the TMax EFI Controller and Auto Tune module (first generation)on my SG forover 5K miles with a base map that was not a very close match to my bike's setup, but the closest one available. After riding 5K miles (over many months)with the TMAT, I hada dyno run done and discovered the bike was makinga paltry80 HP and 99 TQ max.Low numbers for a 103". Gas mileagewas 30 mpg. Seemed that the culprit had to be the mismatched base map.This prompted me to getthe bikedyno tuned byanauthorized TMax tuner. After thedyno tune, the bike was making 90 HP and 111 TQ max and the fuel mileage increased to 35 mpg.
Ifyour base map is not agood matchforthe bike's set up, then the Auto Tunecan not produce the optimally tuned motorcycle, no matter how many milesyouput on the bike. It can onlymodify the base map to a certain extent, then it can do no more. Itstill took a trained tech to tune the bike using theSmartlink Software program and a dynoto get thebike tunedoptimally. However, if the base map is a good match for the bike's configuration, then the ATshould tune it perfectlywithno need for a dyno tune.
My advice: keep searching for a better base map, and if you can't find one, get the bike dyno tuned by a certified TMAT tuner.
BTW, I'm definitely a fan of the TMAT. Good luck.
Old Aug 5, 2007 | 04:10 PM
glens's Avatar
glens
Or just ride what you got and periodically modify the base map according to what the autotune has learned. Pretty soon you'll have autotune tables that will "float" and not bounce hard off their ceilings/floors.
Old Aug 5, 2007 | 06:24 PM
Akitakoi's Avatar
Akitakoi
I'm ready to buy a TMax, is the installation instructions available online? How about the maps?
I want to make sure there is a map close to what I have and one close to what I am going to do.
