Isolated Drive System insall
Why is this so intriguing?
Is there some problem that was born with the 2007 models that I have not expereinced?Call me stupid, but it seems like a "fix" for something that wasn't broken and not only are they making $$$ on the "conversion kit", it's a perpetual revenue stream, as the isolators will need regular replacement. I can't wait to see how much they charge to replace them, while the wheel is off for a tire. I bet it's an extra hour labor to install a bag of rubber widgets that are manufactured for $1/set and sell for $59.95....
What am I missing?
I dont have any issues with vibration, noises, etc and can run around all day long in 5th at 50 mph, but only after modifying the engine.
Thing is with this sprocket dampener (I'm pretty sure my first-year Honda Interceptor had one in '83 (or thereabouts)) it's not taking lash out, it's putting more in. But it's a soft lash and mostly goes unnoticed.
I dont get some of the comments above, I dont see the IDS as a fix for anything, it will just make for a smoother ride thats all. They should have been fitted to all HD models as stock since the 1970's. Hell my 1976 Kawasaki Z1b had them as standard, as did every bike right upto my tuned Triumph Speed Triple. As for service, well I changed them on my Z1, but only because I was doing a complete overhall and they were so cheap that it wasnt worth leaving them in, but that said I couldnt see anything wrong with the old ones.
My mates Suzuki 2006 GSXR1000 has them and you cannot tell me that a HD is going to give the rubber dampers a harder btime than that.
Service item, yes, wear item yes, problem no. Everything on a bike is a wear item, and will eventually need changing, but if they last as long as the belt who cares.
Just MHO
Wb
So... I should not buy one becauseyour bike runs perfect? I don't get it.
If some of these guyswant to spend 216 bucks on a band aid let'em.
What I also don't get is some people trying to make people feel bad for buying Harley's fix for the problem.
What am I missing?
IDS or what ever HD calls it has been around for decades. On Metrics! they hold up well and should, considering most crotch rockets pull much heavier torque and horsepower loads, last quite a long time
