FLHRC Chrome Hand Controls Question
Old Aug 6, 2007 | 01:45 PM
gliderman's Avatar
gliderman
Default RE: FLHRC Chrome Hand Controls Question
My advise would be to take off your stock controls, send them to a chrome exchange service such as "chrome that hog" and pay about $250 for the entire set of chrome parts. Reinstall them and be happy!! There are plenty of chrome exchange shops around the country that offer this. The chrome is often better than that of the MoCo............
Old Aug 6, 2007 | 02:01 PM
xxxflhrci's Avatar
xxxflhrci
I have 129 buck chrome controls from www.cyclesupplywv.com They are Midwest brand. Several others sell them for about the same price. I have had them for 7 years and have had no problems. I have installed several sets for friends and had no problems, either.
[IMG]local://upfiles/17633/D874C294A17C450C8964B0D0B59A8A92.jpg[/IMG]
[IMG]local://upfiles/17633/C1AA0C7A3A06426DB5FB8D45D213C7EC.jpg[/IMG]
[IMG]local://upfiles/17633/705A3B0E14D449709F3DE0A6FEBD229A.jpg[/IMG]
Old Aug 6, 2007 | 02:07 PM
jakedog's Avatar
jakedog
Great price, unfortunately they only go to 2006..... I would need 2007 which are hard to find in the after market.
Old Aug 7, 2007 | 12:53 AM
Comfortably Numb's Avatar
Comfortably Numb
Sorry I'm of no help. I bent over and took it for the full set of HD controls, levers, switch housings, and switch caps from Zanottis.
They look sweet.
CN
Old Aug 7, 2007 | 01:09 AM
mchacon's Avatar
mchacon
Either way when it's all said and done. You'll love the look.
Old Aug 7, 2007 | 02:53 AM
Drelkor's Avatar
Drelkor
ORIGINAL: jakedog
There is no difference between 2006 controls and 2007 controls with the exception that the clutch lever has a little tang on it to depress the clutch posiiton sensor. If you use a clutch lever for a 2007 model, you'll end up with exactly the same setup.
You may also have to drill a small hole in the switch housing for the clutch switch, but HD doesn't differentiate the 2006 housing from the 2007 housings either so I'd expect that you'd probably have to do that even using HD parts unless they have re-engineered them under the same part number for 2007.
Drel
Old Aug 7, 2007 | 10:06 AM
IceHeritage's Avatar
IceHeritage
I had the same Problem and had to eventually go with the Dealers Controls, The Controls are Re-Engineered for 07 and below but there definitely is a difference and they are Not upward Compatible
vtdiesel
Oct 9, 2013 02:42 PM
bambamblazer
Jul 22, 2013 11:39 PM
diddydido
Aug 6, 2011 02:12 PM
coronerrpm
May 15, 2010 11:38 PM
blown alcohol
Feb 8, 2006 01:48 AM
