quick question for you touring members... I washed my 07 Ultra and found a small cone shaped rubber thing on the floor... Any Ideas??
How small is "small"?
If it is about 1/4" round at the bottom, it is the rubber boot off your odometer reset button from the dash, just screws on and they have been know to vibrate loose. Running a rag over it while loose will knock it off.
Easiest way to check is to look for the empty hole where the reset button used to be. It will fall back into the inside of the fairing when the nut and boot come off.
