Not quite the same bracket, but Ciro has something similar here.
As mentioned above, I use the Techmount for my GPS and phone on my King. Uses an extension that centers above the bar clamp cover. This is the one sold on Law Abiding Citizen. I also run a USB power port from the ACC plug, so power is switched on or off.
I do not believe I cannot use the Garmin cradle for the GPS with that mount. I have looked at the Ciro mount several times. And seen a couple in real life.
Im interested in these also. How has your held up? With everything Ive read about the iPhone camera damage without a vibration dampener it was Quad Lock or SP mounts as my options.
It's doing great. The antivibe mount seems to work but Im not really sure. At idle, the phone shakes a bit but Im not running video while Im riding. But as you know, once you are going it smooths out. I like since it mounts into place, you just have to either buy a case or a universal kit. No issues so far.
