The P0107 Code MAP Sensor
Old Aug 3, 2021 | 09:08 PM
Hawg295's Avatar
Hawg295
Default The P0107 Code MAP Sensor
My fuel injectors were plugged up this year after about 1200 miles of riding. And the same thing happened last year. I inspected the fuel tank and it was fine. Being that I have 2011 Electra Glide I decided to replace the fuel line. I cleaned the fuel injectors and I was ready to go or so I thought. It was throwing several codes and it was running rough, high idle on start, cutting out. I got the P0107 code and the check engine light came on. I sent Vance&Hines and they said everything looked good. I replaced the MAP sensor and I still had the P0107 code and check engine light. I cleaned the grounds and a few other things. I took it out for a ride today and it ran great with the check engine light on and the P0107 code. I tried to clear the code several times without any luck. I’ve been working on this for a week now. Any suggestions?? Thanks in advance.
Riffraff123
Electrical/Lighting/Alarm
Apr 2, 2020 07:49 PM
Bogie_71
Sep 25, 2016 12:12 PM
clap
Jul 2, 2014 11:16 PM
fireleu6169
Feb 10, 2012 03:23 PM
fryeca
Jan 24, 2007 12:16 PM
