Wheel bearings this go-round?
Old Aug 24, 2021 | 11:01 AM
strych9's Avatar
strych9
Originally Posted by jake24lt
A little pricey, and no ABS bearings that I can find.
Wow...You can buy the entire All ***** kit (front and rear, and sprocket bearings w/ ABS) for that money.
Old Aug 24, 2021 | 11:14 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
SKF and *** make good quality bearings that would cost a fraction of that $86.
In another application there is no guarantee that a ceramic balled bearing is any better than a steel balled bearing.
Old Aug 24, 2021 | 01:11 PM
67Shuv's Avatar
67Shuv
I’ll be replacing them and making sure they’re greased inside the seals adequately before they go in. I’ve got access to the tools and all. Seems like the vast majority of sealed bearings I’ve ever installed in anything eventually die from lack of lube.
Old Aug 24, 2021 | 05:00 PM
MRFREEZE57's Avatar
MRFREEZE57
I lost a rear one on the low rider at 23k, ones with the Timken name can be found at a bearing supply house. even so they do not have that much grease, I pack them with wheel bearing grease before installing.
Old Aug 25, 2021 | 08:29 AM
jasle's Avatar
jasle
Originally Posted by 2black1s
I'd say inspect... If they turn firmly but smoothly they are fine. Although, if you continue to run the bearings, popping out the seal and repacking with fresh grease is a good idea.
The main reason for premature bearing failures is improper installation. The first bearing is pressed in until it bottoms in the hub. The second bearing is then pressed in only far enough to eliminate the clearance between the bearings and the bearing spacer. If the second bearing is pressed in too tightly (too far), the bearing(s) will have too much side load on the outboard side of the outer race and the inboard side of the inner race. If it is not pressed in far enough the side loads are opposite once the axle torque is applied. These excessive side loads will wear out the bearings prematurely.
The correct bearing depth is when the spacer is snug between the bearings. It should take very firm finger pressure to move the spacer. If you can easily move the spacer using finger pressure, then the bearing is not pressed in far enough. If you can't move it at all with firm finger pressure, then the bearing is pressed in too far.
I've got over 240,000 miles on the bikes listed in my signature (100,000+ on one of them) without a single bearing failure.
very good point. I install one bearing. Measure depth. Shorten spacer until it matches the depth so I can just press bearing in to the shoulder. On our race bikes we do this right out of the box.
Old Aug 25, 2021 | 04:20 PM
bklynbob's Avatar
bklynbob
Have you run them? I'm interested but haven't seen first hand account with harleys yet, smaller much lighter machines yeah.
I’ve got around 20k on them,they roll real smooth.so far so good. Changed out the wheels and figured I’d go with the ceramics.
Dragbike magazine has a good article on them in their tech section a while back.
Old Aug 25, 2021 | 04:24 PM
bklynbob's Avatar
bklynbob
They should spend some money on website that actually helps the customer. The only info is a phone #
yep, I ordered mine over the phone.
TheRoadKing101
2014-2024 Touring Models
Sep 27, 2020 12:28 PM
EasternSP
51
Jun 23, 2020 07:32 PM
Curtis629
Wheels/Tires
Oct 6, 2009 06:14 AM
vernh59
Apr 20, 2007 05:42 PM
twincammer
Dec 11, 2005 03:15 PM
