2021 Road Glide Limited Fuel door sticking
Old Aug 31, 2021 | 07:58 PM
afloridapi's Avatar
afloridapi
From: Greater Daytona Beach Area and Fayetteville, NC
Default 2021 Road Glide Limited Fuel door sticking
2021 Road Glide Limited fuel door sticks when you push the button to open. I have to use my fingernail while holding button down to open. This happened before and the dealer fixed it in about 10 minutes. Has anyone had this problem? Does anyone know how to fix?
Old Aug 31, 2021 | 08:48 PM
nedster's Avatar
nedster
Mine does it all the time; I adjust the silver tensioner under the lid/ works for a while then it won’t open. I just use my finger nail to pull it up.
Old Aug 31, 2021 | 08:55 PM
bunk216's Avatar
bunk216
Take a 90* flat head and bend the prongs underneath that push the door up. Like said above you may have to do it every few months. My buddies only had to adjust his once and his has been good for a few years.
Old Aug 31, 2021 | 09:31 PM
RET_SCPO's Avatar
RET_SCPO
Mine sticks on my 2020. I apply some be grease to the spring and it fixes it for a few months at a time.
Old Aug 31, 2021 | 11:15 PM
Grouser62's Avatar
Grouser62
Make sure the springy tongue thing is straight into the catch. Give a slight twist of the nut if not. Usually helps mine for a bit but ya these doors can be temperamental.
Old Sep 1, 2021 | 04:04 AM
geezer glide 56's Avatar
geezer glide 56
If you push down on the bottom of the door while pressing the button, it will come up.
Old Sep 1, 2021 | 07:06 AM
Drat's Avatar
Drat
Had to rotate mine back to center. Its just another thing that has to be checked. Only takes a few seconds to rotate to center with your fingers.
JONNIEROCK
Jul 21, 2021 04:37 PM
dep3839
Jul 30, 2010 01:49 AM
FXRRYDR
Apr 17, 2010 06:23 PM
mysticrains
Aug 14, 2008 10:43 AM
