New Bagger owner - issues
Old Sep 9, 2021 | 08:51 PM
btsom's Avatar
btsom
If you decide to replace the compensator, (I would recommend it) the rotor on the engine crank shaft inboard of the compensator will also need to be replaced. All of the new compensators require the new rotor including the latest of the Harley comps. The parts guy is not trying to con you out of more money.
Old Sep 9, 2021 | 10:17 PM
F150HD's Avatar
F150HD
Originally Posted by danzio
I had all the symptoms of a "bad compensator". Batteries wouldn't last 2 years, starter clutch issues, loud bang from primary on hot starts...
I began doing some research and came to the conclusion (my conclusion and I'm not saying it will work for all compensator problems) that the BANG, CLANG, CLUNK was not caused by the compensator but was a symptom of a different problem..
^^this. "hot start kickback". I do a starter blip on my TC96 to remedy when bike is hot (no issue when cold and all has bled off) but wish I had some kind of compression release.
those easy start cams are a good idea.
truckerdave
Mar 26, 2024 09:31 PM
JUSTIFIABLE
Apr 19, 2020 08:27 PM
SavageChopper
Jun 1, 2019 05:07 PM
garand
Jun 29, 2011 12:59 AM
stng_96
Jun 2, 2010 10:58 AM
