Diagnostic Code Help!!!
Old Sep 14, 2021 | 01:23 PM
Spartan2021's Avatar
Spartan2021
Stage III
Exclamation Diagnostic Code Help!!!
Hello everyone, I need some help on identifying some diagnostic coeds on my 2004 Road King. Last week my check engine light came on at it was only throwing on code. P = ECM / ICM (Engine / Ignition Control Module) P0108 Map Sensor Failed High. I did some research and decided to replace the MAP sensor. That seemed to fix the problem and toady when I was on my way to work the check engine light came on again. Now its throwing three codes. The bike is running great. There is no loss of power or any kind of sputtering or backfire. Can someone help me figure this out. Thanks for your help.
P1356 Rear Cylinder No Combustion
P1358 Rear Intermittent Secondary Combustion
Old Sep 14, 2021 | 01:28 PM
FlamedFXR's Avatar
FlamedFXR
As long as it is running decent just clear the codes. It's possible they are historic from the last issue.
Old Sep 14, 2021 | 06:56 PM
memphisharley's Avatar
memphisharley
clear them see if they come back...if so it could be due to loose or broken wiring to a sensor and not the sensor itself. once a sensor is replaced and verified as good and codes come back the same time to look at the wires. most of the sensors on my 12 use the same ground. if one is broken..and mind you it doesn't show broken by looking at the wires..just need to have a few broken strands on those wires and the voltage won't add up and the ecm will get pissed.
Old Oct 2, 2021 | 04:39 AM
RiderX's Avatar
RiderX
Is there a 'C' or 'H' at the end of them. 'C' stands for current and 'H' is for historical.
Old Oct 2, 2021 | 05:55 AM
kel03's Avatar
kel03
Have a read https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Oct 2, 2021 | 08:04 AM
touchdown's Avatar
touchdown
It's the motor co calling to say come on in. LOL
Spartan2021
General Topics/Tech Tips
Oct 20, 2025 12:58 PM
rasmukri
May 2, 2020 08:34 PM
tennman0258
Oct 6, 2014 11:46 AM
Scaryjerry58
Dec 14, 2008 10:22 AM
jeff986301
May 15, 2008 10:27 PM
