Factory fork oil different in each fork?
Old Sep 21, 2021 | 10:31 AM
ZBoT's Avatar
ZBoT
Originally Posted by Weeboy1
I meant the vendor that sold you the bike.
Oh gotcha. I have not. I bought it new from a H-D dealership about 2 hours from me. I'm not really concerned about getting it covered under warranty or anything like that. I just would like to know why it's different in each fork. If it is a problem (not just different oil), I would like to figure out why it happened to prevent it from happening again. I plan to thoroughly inspect the forks and reassemble with the Legend cartridges.
Old Sep 21, 2021 | 10:55 AM
RK_Classic's Avatar
RK_Classic
Very strange, The brown looked better then mine when I changed fluids, mine was black and smelled real bad.
rk classic.
Old Sep 21, 2021 | 12:21 PM
Weeboy1's Avatar
Weeboy1
Not warranty wise just curious if they could explain it. Show them the pics.
Old Sep 21, 2021 | 01:28 PM
dajogejr's Avatar
dajogejr
Gotta tell you, this one peaks the Weird Sh** O Meter for the day.
I was under the same impression internals were different in one leg than another, as they were in my 05…but, they stopped that a while ago I believe.
Weird… For sure.
Old Sep 21, 2021 | 02:53 PM
Jackie Paper's Avatar
Jackie Paper
Harley's Hydraulic Fork Oil Type E is died red.
It appears identical, viscosity, color and smell to OEM Honda's rear hydraulic pump rear differential on their 4X4 small SUVs.
Maybe Harley spec it like you see for what two of their heavy viscosity oils would do being too hard a ride and two lighter ones, too soft.
The two shocks are tied together top and bottom. One would not know what other was doing since they work as a pair.
ZBoT, you sure don't give things long to wear out.
Old Sep 22, 2021 | 05:21 AM
ZBoT's Avatar
ZBoT
That is possible. Wondering why they wouldn't list the two different fork oils in the service manual though. Service manual is only calling for 'TYPE "E" HYDRAULIC FORK OIL (62600026)' in both forks. So based on the service manual both forks should have had red oil in them.
Old Sep 22, 2021 | 05:49 AM
Jackie Paper
My thoughts is the fluid supplier probably supplies it in bulk drums and the new one lacked the dye additive.
Maybe they changed the formula for the dye. What's in DOT 5 brake fluid for purple turns like that in a year.
Or your bike had a unique build sheet that the owner and your service manual did not address.
I'm just guessing however. Call the mothership. Get someone there to let you email your picture so they can get it to the right source for an answer.
Your not going to get an answer that's worth anything from someone who normally answers a phone.
An don't tell them anything you're doing other then maintenance..
Old Sep 22, 2021 | 06:05 AM
ZBoT's Avatar
ZBoT
I'm thinking along the same lines. Same type of oil just different color. Still seems odd though and would be interested in knowing for sure. I've never called MoCo. I feel like I'm just going to get the runaround but it's worth a shot. Thanks for the thoughts and ideas.
Old Sep 22, 2021 | 08:22 AM
lp's Avatar
lp
Mine was the same way and color (a 2017), but it could have been because the Teflon on the bushings were worn almost completely through.
No idea why, and only on that one leg. After a fluid and bushing change, all was good the next time I opened it up two years later. Weird.
Old Sep 22, 2021 | 08:39 AM
ZBoT's Avatar
ZBoT
Thanks for the reply! Just curious, how many miles did you have on it when you did the first change (and noticed the different colored oils)? Mine had 6k and the bushings were all like new with all the Teflon still in place. Seals looked good too.
