Thanks for the reply! Just curious, how many miles did you have on it when you did the first change (and noticed the different colored oils)? Mine had 6k and the bushings were all like new with all the Teflon still in place. Seals looked good too.
About 15K. I only got into it to change sliders to black powdercoat.
And yeah I figured as much. I looked at your pic the best I could, and they looked good.
Thanks! Well glad to know I'm not the only one (misery loves company lol). One more quick question if you don't mind. Were the bushings only worn in the side with the brown oil? Were the bushings in the fork with clean red oil ok?
Yes, just the brown side. Red side was perfect. When I checked back 25K miles later both sides were dark-reddish - a non-issue and expected. You know, just so you know what's probably coming...
Huh. Wonder if the teflon on my brown side was wearing through but just hadn't gone through all the way yet. Causing the red oil to turn brown. Interesting. I'm going to take a closer look at the old bushings on that side again. Also I appreciate the info that they were ok (and still red oil) when you checked them 25k later. This info helps a lot. Thanks again!
Obviously different oils after Ip's post. Not sure about what Harley does now but in the past, they outsourced the forks. They probably specific a certain rebound rate and manufacturer got it that way.
Maintenance doesn't worry about maintaining that rate.
Mine has been changed once at 20K. Both were still red and that's been years ago. When I saw your post, I dug back thru my wall shelf to the old 1/2 full bottle that was left from the two I had when I changed it. After dusting years of dust off it, It was still red.
My 04 now has 50K on it. Few years ago, with all the doom and gloom one sees on the Forum and suggested maintenance in manual, I pulled the steering bearings down. Pain in the butt even on my simple Softail tail.
Total waste of time. That like the fork oil is not happen again by me anyway.
I blew a fork seal (right side) in Butte Montana while on a road trip in August. I got it replaced at the HD dealer there, and while it was apart they checked the upper leg to make sure it wasn't bent. It was, and there was also pitting in the chrome. I'm sure this was the cause of losing the seal. In your case, it may also be why you have water intrusion.
I blew a fork seal (right side) in Butte Montana while on a road trip in August. I got it replaced at the HD dealer there, and while it was apart they checked the upper leg to make sure it wasn't bent. It was, and was the cause of losing the seal. In your case, it may also be why you have water intrusion.
Thanks for the reply. I thought the same thing (although my seals were not leaking at all). So I measured both fork tubes with a dial indicator when I had them apart. They were straight as an arrow with less than 0.001" runout (spec in manual is to replace fork if runout exceeds 0.008"). So this was not my issue.
