Six speed or five speed Road King
Old Oct 15, 2021 | 01:25 PM
2ndheart's Avatar
2ndheart
Default Six speed or five speed Road King
How is the ride on pre six speed road kings. In both highway and in town riding. Specifically the 2006 vs the 2007. Trying to decide which to buy.
Old Oct 15, 2021 | 01:29 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Isnt the 06 an 88 and the 07 a 96"
Old Oct 15, 2021 | 01:36 PM
Ironhandjohn's Avatar
Ironhandjohn
Can only speak to a stock 88CI & 5-speed, but its sweet-spot is around 75MPH. Any faster and the engine starts to feel a bit buzzy.
Old Oct 15, 2021 | 01:46 PM
WP50's Avatar
WP50
The 6 speed does lower the hwy rpms a little.
If you get use to the 6 speed you might miss it some if going back to a 5 speed.
When I ended up with an 08 Ultra I made 2 trips of about 7-800 miles.
Didn't get out of 5th till right at the end of both trips. Forgot I had a bike with a 6 speed.
I rarely put it in 6th and not until 80-90 mph speeds are being run.
If I Iike the bike either 5 or 6 will suit me
WP
Old Oct 15, 2021 | 02:26 PM
Rob Harper's Avatar
Rob Harper
I agree with Ironhandjohn on the 5 speed. Mine is a 2001 with 95" big bore kit, stage 1 air filter, drilled qty 4 - 3/8" holes in each baffle of the stock mufflers. 70-75 is fine. 80+ feels like it's working too hard. Although I don't think 80 will hurt anything, I don't ride over 75 very often, usually 65-70. The bike gets around 47-48 mpg with just me on it, no windshield. In town the 5 speed is fine. Unless I was doing long high speed runs, I wouldn't hesitate to get a 5 speed if the bike and price are right.
My Ultra with 103 and 6 speed has longer legs for sure, 80-85 no problem. Stock air filter (soon to change), gutted cat, stock CVO mufflers (probably will drill some holes in the baffles) Usually ride same speeds 65-70, 2-up and 12" windshield. Haven't had bike too long, but it's been averaging 42-43 mpg. In town I never use 6th gear.
Old Oct 15, 2021 | 02:27 PM
Thingfish's Avatar
Thingfish
2007 had straight cut gear that whined....I'd recommend 2008 or newer if you want 6 speed. 6 speed is nice....
EDIT - I Was wrong..this was on ly 2006 Street bobs. 2007 RK should be fine for a 6 speed.
Old Oct 15, 2021 | 02:42 PM
roussfam's Avatar
roussfam
I've heard that before. Not the whine, the statement. I have an 07 Bagger, never noticed anything different from my 03 Bagger? Go figure
Old Oct 15, 2021 | 02:54 PM
Thingfish's Avatar
Thingfish
You are right!!! My bad. it was the 2006 Street Bobs that were the very first to get the 6 speed. I think they fixed it by 2007.
- Fixed my earlier post. Thanks!
Old Oct 15, 2021 | 03:23 PM
Dano523's Avatar
Dano523
Work the math the other way.
Hence OEM 6 speed in a RK means that you have a twin cam or later motor (2007 and later), while 5 speed trans means that either twin cam with spring loaded cam shoe tensions (bad), or older evo motor.
As for touring models, 2006 was the first year that Harley got the front and back tires in the same line.
Myself, love the evo motor due its simplicity/bullet proofness (single cam) and why I have a 97 RK, but on the other side of the coin, when Harley get the front and rear tires in line on the 2006 and later models, makes for a better handling bike over-all.
So short of the trans begin changed out on the bike and don't want the evo motor, would be nudged to go with a OEM 6 speed trans, which would put the bike at 2007 or later.
As for the trans themselves, unless your going to see a lot of 80mph plus trips, either trans if fine.
Note, can pull 80mph in third gear on my 5 speed RK, have run at over 120mph at times, so it really comes down to the the 6th gear bike having just a slightly lower final drive in the end when you are running at higher speeds through out the trip really.
Old Oct 15, 2021 | 03:39 PM
TwiZted Biker's Avatar
TwiZted Biker
Check the final ratios of the 6 in question, not all were an actual upgrade over 1-1 final drive. What harley did with the engine size increase was change the primary ratio to drop RPMs a bit and give it more legs. The extra gearing and inches balanced any gaps and lugging getting up to speed.
