2012 HD SG Throttle Position Sensor
Old Dec 17, 2021 | 12:35 PM
jimglassford's Avatar
jimglassford
Originally Posted by NaptownRR
Thanks for all the replies, but does anyone know if the TPS on a 2012 can be fixed or is it a repairable item.
The throttle sensor has two distinct outputs, typically that have different slopes. The ECU can compare the two slopes to confirm the sensor is operating. So, it may not be a case of no signal. It could be a case of two signals that do not match a predetermined map. Hall-Effect sensors are not repairable, but rarely become defective.
Old Dec 17, 2021 | 06:44 PM
memphisharley's Avatar
memphisharley
I'll give that a shot, it's cheaper to go that route.
yeah..do the same with the temp sensor plug wires too as they are the same as the tb wires.
good luck with her.
Old Apr 6, 2022 | 06:40 AM
NaptownRR's Avatar
NaptownRR
6th Gear
I replaced the TMAP sensor and that seems to have done the trick. I didn't replace the TMAP wires as suggested.
Adam Reuter
Engine Mechanical Topics
Jun 11, 2020 10:33 AM
cowboybob56
Sep 21, 2017 10:02 AM
JonGolden
Jun 1, 2016 09:02 PM
kwrose66
Dec 30, 2012 10:06 AM
09rkpolice
Sep 18, 2011 11:35 PM
