No spark
Old Dec 17, 2021 | 10:54 AM
Torches's Avatar
Torches
2nd Gear
Default No spark
New regulator new stator yet no spark, ran perfect before it shut down, no hint of any problems, everything checks out okay, down to checking switches, not sure where to go next , need help
1997 Electra glide, with carburetor basic harness from ultima
Old Dec 17, 2021 | 10:57 AM
OkieBill's Avatar
OkieBill
Well, bike model and year may help with solicitation of assistance. Throw in a bit of background such as why you changed the stator and rotor - burned up? Upgrade?
Old Dec 17, 2021 | 11:05 AM
Torches's Avatar
Torches
2nd Gear
Default No spark
No the stator was not burned up neither was the regulator, everything tested good the coil isn’t isn’t firing, tested the coil and it is good , how often does the kill switch on the handle bars go bad
Old Dec 17, 2021 | 11:09 AM
eighteight's Avatar
eighteight
Is there power to the coil input ?
Old Dec 17, 2021 | 11:20 AM
Torches's Avatar
Torches
2nd Gear
No power to any of the leads on the coil in the on position
Old Dec 17, 2021 | 11:48 AM
eighteight's Avatar
eighteight
Id tell you view the wiring schematics at HD service portal and work your way backwards but your Ultima harness may or may not share the color codes.
Old Dec 17, 2021 | 11:53 AM
Torches's Avatar
Torches
2nd Gear
Okay thanks I’ll check it out anyway it might help
svarnster's Avatar
svarnster
as second post mentioned, background, year and model, which stator did u use, why did u change it. First guess u wired it wrong. second guess u pinched a wire. third guess bad stator or regulator............. good luck and welcome to the forum.
Old Dec 17, 2021 | 11:54 AM
Torches's Avatar
Torches
2nd Gear
None of the above, possibly kill switch is grounding out
Old Dec 17, 2021 | 12:02 PM
eighteight's Avatar
eighteight
Doesn`t the kill switch stop the engine from even CRANKING ?
Doesn`t just kill the spark
The stator and V-R keep the battery supplied with voltage don`t see that interfering with supply to coil
Try to locate the coil feed wire leaving the IGNITION MODULE ?
