Tappet selection
Steve,
I'm always willing to learn, and I trust in your experience... but I'm a little confused by the connection you draw between the S&S tappet video and a comparison of the size of the oil holes between the S&S quickie pushrods and chevy lifters...??
I just watched the S&S tappet video again and all they talk about are the flow rates between the S&S Premium lifters (I know they are no longer made) vs the chevy lifters...
Now they are certainly making this video to push their lifters, and they make a couple of "cheeky" comments to try to exaggerate their point... but the video times the oil flow between the heads, of the same engine, same oil, same oil temperature, same oil pressure but with two different lifters between the heads. It shows two distinctly different flow rates to and through the rockers in the video.......
They don't mention anything about the size of the holes in any lifters or even discuss their quickie pushrods...?
They mention the difference between oil pressures in a Chevy V8 vs a Harley engine (true) and the difference of recommended oil viscosities (true) as a possible basis for differences in the lifter designs... They are claiming that each lifter is designed for a different application, and that is causing the flow difference...
I have taken apart a lifter before, mostly out of curiosity, and it would seem to me that there are several things internal to a lifter that can affect oil flow, besides the oil port size at the pushrod, such as the piston size (volume) and internal passages effects on the pressure passing through the lifter body...
With any pushrod, the oil port size is pretty much the only "restriction" in that part...
I would love to know/understand your reasons for believing this video to be a misrepresentation of the two lifters oil flow rates.... and how you connected the S&S pushrods to this experiment, and conclude they are restrictive...??
I'm not trying to defend the video, nor dispute your experience.... I am just trying to learn from your experience, and understand your conclusions...
https://www.youtube.com/watch?v=fMoRaHJRrhc
Now there are many HD engines running the SnS "Quickie" pushrods and many others who have stuck their name and rebrand the SnS pushrod selling it out there today. How many are failing, I have no idea, but if your going to believe the SnS lifter video, that the additional oil flow is required, then you must also except that the SnS "Quickie" pushrods will cause your engine to fail due to the reduced oil Flow to the heads that they cause!
