Earlier service manuals call for anti seize on spark plug threads, but M8 service manual says spark plugs must be clean and dry.
I go by the whatever the service manual calls out.
I always put a thin coat on my shovels, evos and TC's. Never had a problem. I havent changed the plugs yet in our M8's. The wife and I had a pair of 107 STG's and traded them at different times for 114 STGS. I figure keep trading and i wont have to worry about, do i or dont i, use anti seize.
the first post I quoted shows a 10mm thread chaser next to a harley plug, so I'm guessing its from an m8. I'll keep putting antiseize on my M8 also...
Using anti-seize can't hurt...
Unless you use a torque wrench to tighten your plugs, and use a "dry torque spec" for a plug with anti-seize... In that scenario, you will be over-torquing your plug and could damage threads...
