Spark plugs
Old Jan 17, 2022 | 02:54 PM
  #71
FlamedFXR's Avatar
FlamedFXR
I'm wondering if anti-seize affects grounding of the plug, that's the only reason I can think of why it would be recommended against using it.
Old Jan 17, 2022 | 03:14 PM
  #72
MotoJockey's Avatar
MotoJockey
What is anti-seize compound made of?
What is Anti-Seize? Straight out of the tube or bottle, anti-seize is made up of a high-quality grease base and lubricating solids (copper, graphite, aluminum, calcium oxide etc.), which are suspended in the grease.
So, you have copper, aluminum, and graphite in it, all of which are electrically conductive. No ill effect on plug grounding......
Old Jan 17, 2022 | 08:26 PM
  #73
hattitude's Avatar
hattitude
They recommend against it because it affects the torque spec.....
Unless stated to use anti-seize, spark plug torque specs are "dry torque" specs. The addition of anti-seize will then yield a higher torque value than the torque wrench is set at...
Old Jan 19, 2022 | 11:23 AM
  #74
xcbullet's Avatar
xcbullet
I thought we learned anti-seize torgue to 12 ft/lbs and all is well. Are the M8's using a different thread?
Old Jan 19, 2022 | 12:24 PM
  #75
d_slat's Avatar
d_slat
yup. They are only 10mm plugs in the M8.
gingerpeth
Apr 11, 2021 10:03 AM
Cowboy Alex
Jul 19, 2012 10:55 PM
grunt25inf
Sep 18, 2007 02:06 PM
alaskajeff
Jun 13, 2007 04:17 PM
carlosjc401
General Topics/Tech Tips
11
Sep 28, 2006 11:11 PM
