2014 Street Glide shock preload
Every time I hit a moderate bump it felt pretty hard. At one point I was in a right curve and the road had a series of spots where it was lifted (common in winter). The result was the bike literally bounced towards the center line, and I was almost off the seat a couple times. I never had that happen before and needless to say, not happy!
From what I'm reading, adding preload is going to make the suspension even more stiff and just make things worse. True? I'm not sure what I'm supposed to do here. Throw 20 pound sandbags in the saddlebags?
NOT how I expected my first ride to go! Considering the nut I just spent to get this bike, the last thing I want to do is have to spend more on different shocks. Sigh. Any ideas?
Almost all shocks will need some preload, unless you weigh like 120lbs..... you weigh 215, so I feel confident in saying the "no preload" you set the shocks at, is way too light... I would suspect at that weight, for most shocks, you would be near the middle for preload adjustment, or on a shock with heavy duty springs, maybe the bottom 3rd.....
What you are feeling is probably the shocks bottoming out, because you have no preload....
In a simplified nutshell.... too much preload and your suspension will feel firm, too little preload and your suspension will bottom out, which is harsh, and be too springy in between bottoming out...
All shocks have a "stroke". That is the entire length the shock can travel. Preload is just setting your Rider Sag, so that the shock, with rider/gear on board, is at 2/3 of maximum "stroke".. You want the preload adjusted with the bike, rider, and gear, so the shock is in a point of its travel that will give 2/3 stroke for compression and 1/3 stroke for rebound...
For example, if you have a shock with max stroke of 3"... then with you sitting on the bike, and the bike loaded as you intend to ride it, the shock is compressed 1" down from max height
On a coil over shock, the springs hold up the bike and the internals of the shock control the ride quality/damping...
Many shocks only have a preload setting. They may not ride well even with the proper preload due to the quality/design/weight range of the shock...
As the cost of shocks increase, so does the quality of the design (emulsion to gas separated to gas separated with a remote reservoir) and the ability to control more than just the preload setting. Some quality shocks allow for overall damping control, and some individual rebound and compression damping control...
The above was an oversimplified explanation..... but hopefully you get the idea...
If you research "setting shock preload" along with terms like "sag", "rider sag", and "shock stroke" you will get hours of reading and a much better understanding then my post offers..
Good luck with your shock adjustment
