Center Stand Query
Old Mar 9, 2022 | 09:03 AM
Rob175's Avatar
Rob175
Just buy a JACK.......you won't regret it and when the times comes to sell it you'll get some money back. They're also the best way to maneuver your cycle into tight garage corners or spaces with zero "struggle". Great for storage, cleaning, maintenance etc. Lots of good brands on the market....some even "like" the cheap Harbor Freight ones (not me).
Expand your thinking and consider a good Jack/lift.
Old Mar 9, 2022 | 09:19 AM
subgunner's Avatar
subgunner
Had an EZup on my 2013 Road King. Worked OK until Howard worked up a set of Ohlins for me. They were slightly longer and while the stand still worked it was like the bike was on a teeter totter. Too bad they don't have adjustable feet like some others. It was sold and I went back to using my lift.
Old Mar 9, 2022 | 09:31 AM
skratch's Avatar
skratch
i bought one of them roller stands for my sportster about 20 years ago. threw it away, it didn't work for ****.
i also recommend getting a good jack/lift. using a center stand to raise your wheel off the ground is great, but you're still crawling around on the ground trying to get to the wheel, valve stem, etc. with a good lift, you get the bike up to a comfortable height and you have much better access to clean, etc.
imo, a harbor freight lift is not 'a good lift'. spend the extra money and get a better one. i had the hf one also cause in my ignorance, thought it would be 'good enough'. hah. when you lift your bike up high, it is very wobbly. not to mention having to strap the bike down on it as well. i have a j&s now, and i have no worries about lifting the bike to max height, and/or removing front or rear wheels without having to strap the bike down.
Old Mar 9, 2022 | 10:52 AM
snerkler's Avatar
snerkler
Looking at the price of the J&S lifts I'm guessing something like this won't be good enough?
Amazon Amazon
Old Mar 9, 2022 | 11:44 AM
skratch's Avatar
skratch
it may be. all depends on how far the support is spaced. the j&s support arms are located 15'' center to center, with the footprint being equal to that. the one you linked is 12'' lifting area, and 14'' on the footprint. know anyone who has a jack over there you can test? i imagine the j&s is going to be very expensive to ship overseas....
Old Mar 9, 2022 | 12:02 PM
snerkler's Avatar
snerkler
It is, and I can't find a UK supplier. I've found a Clarke one that gets 5/5 reviews with 55 reviews including Harley and Indian owners 👍🏻
Old Mar 9, 2022 | 12:21 PM
snerkler's Avatar
snerkler
Well I'm glad I watched some videos as I'd have put the lift in from the side stand side of the bike but all the videos show them putting the jack in from the other side That's not ideal as this side is up against the wall of the garage so I'll probably have to wheel it out on to the road (I live on a cul de sac) as my drive slopes.
Old Mar 9, 2022 | 02:49 PM
Rob175's Avatar
Rob175
In my first reply didn't want to mention that I too have a J&S Jack cause I didn't want people to think I was only advocating that brand. Having said that, it's a great product...but yes, its expensive. You DO pay for what you get, and when it's resold as used most command at least 1/2 the original price and more.
There must be someone making a great jack in Europe.....shop around.
Old Mar 9, 2022 | 03:21 PM
skratch's Avatar
skratch
i've put my jack through from the other side before and not had any issues. i did have to tilt the bike toward vertical to give enough clearance for the support arm to slide under.
Old Mar 9, 2022 | 04:34 PM
YZR's Avatar
YZR
Oh good, another jack thread! 🙄
