Condor Wheel Chocks..
Old Feb 12, 2025 | 06:32 AM
  #41
Architect's Avatar
Architect
I have had mine for 12 years, use it in the shop on the floor and in two different trucks, zero issues, good tool. If you have an issue getting your bike out of it, you need to adjust the rocking mechanism. I believe moving it back one notch at a time until you stop having an issue. Maybe call Condor or check their website to be sure. But I had an issue, saw them at a show and they got me fixed up, good luck.
Old Feb 12, 2025 | 07:00 AM
  #42
ksol5's Avatar
ksol5
Originally Posted by FunHuman
This works great, screwed to the floor. $69.99.
1800 Lb. Capacity Motorcycle Stand/Wheel Chock (harborfreight.com)
I have this same one, I bought it for my softail but it easily holds my Road glide in place. I do bolt this to my trailer decking,. and I strap it down securely using quality(Tank) straps and never had an issue, not that I trailer very often but it does work great when I need to.
Old Feb 12, 2025 | 01:26 PM
  #43
Mr. Clyde's Avatar
Mr. Clyde
6th Gear
I have the "Trailer Only" Model SC-2000. I have it attached to a utility trailer and have used it twice, about 200 miles total, it works great and truly makes loading and unloading a one-person job (if you can't get any help). However if I had the purchase to do over I think I would go with the "Pit-Stop/Trailer-Stop" model PS 1500. Reason being you can use it on the ground, not just the trailer.
My step-sons are welders and I'm thinking of having them weld me up some "side-arms" to attach the Condor to, just so I can use it on the ground or in the garage as well as the trailer.
It is a good product.
Old Feb 13, 2025 | 03:24 PM
  #44
Steelernation's Avatar
Steelernation
Wheel Dock is the best. I bought a Condor and the quality was good but trying to get my Street Glide out was a battle. So, I returned it. I suppose if you anchor it to the floor it might be easier. I have a Wheel Dock for my Road glide and one for my Heritage. The wheel dock costs a bit more, but it's so much easier to use.
Old Feb 14, 2025 | 06:14 AM
  #45
Architect's Avatar
Architect
It is adjustable.
Old Feb 14, 2025 | 09:22 AM
  #46
Crabchuck's Avatar
Crabchuck
The Condor is where it's at. Baxley made something similar, but not as good. The Condor says you adjust the rocker saddle back until it comes close, but doesn't touch the ground under the wheel. That's the most secure. But, in the garage, for cleaning or maintenance, you can adjust it forward to get it out easy. It uses the weight of the bike as the clamping force.
I use mine as a catcher at the racetrack. I move it forward so it's easy to get out. No kickstand on the bike. I see guys come in, have to balance and reach for their rear stand. Just looks like a struggle. I roll in, get off, take my helmet and gloves off. Put it on my rear stand, roll it back out of the chock, and then put my front stand and warmers on. At the end of the day, I dock it back in my trailer, roll the bike in and throw a couple straps on it to hold it forward. Hands down the best purchase I've made.
My best story, I got to the track one morning and both my straps had come out of the eyelets. I'd gone over an hour down the highway, and multiple turns to get to the track. I had hit a huge bump after leaving home, and I'm sure that's when they came loose. Bike stayed upright in the chock. (I use endless straps now....).
Old Feb 14, 2025 | 09:59 AM
  #47
hattitude's Avatar
hattitude
The condor is probably the best chock of that design.
I prefer the WheelDock chock. It is a different design, and I feel it has advantages over the Condor style design.
But that is a matter for personal preference... and the WheelDock chock IS more expensive.....
Old Feb 17, 2025 | 04:06 AM
  #48
StoneTrekker's Avatar
StoneTrekker
Both chocks are absolutely good, and it comes down to personal preference. For me the Condor is the best because I bought it first. 😆
Old Feb 22, 2025 | 04:03 AM
  #49
Nearlynn's Avatar
Nearlynn
Stage II
Originally Posted by Nearlynn
Super solid, easy to use, and they hold the bike steady without a hassle. The adjustable cradle is a nice touch, making it work for different wheel sizes.
I’ve been using Condor for a while now, and they make some of the best wheel chocks out there.
Old Feb 23, 2025 | 11:37 AM
  #50
flhf150's Avatar
flhf150
I saw in a previous post that you used the wheeldock in your toy hauler. How does it mount and what sticks up on the deck top of the garage?
