Did not expect that
Glad to hear the WMEo shocks worked well on your Road King. I agree the Bitubo offering is excellent including some of their remote adjustable or hydraulic adjustable shocks. They even have an electronically adjustable system. The twin adjustable is an amazing deal.
I did not realize that on the left fork the clutch cable is zip-tied with a rubber holder to the handlebars which comes very close to the top of that fork. Adjusting the new Bitubo cartridge on this side will take some doing but the adjustments look like they are still accessible.
The ride quality of the total suspension is excellent and I really could not imagine anything being much of an improvement from this setup. I would say with the factory setting on the front cartridge it is more on the softer side than the Progressive Monotubes I have on my Electra Glide. Similar to the stock suspension but soaks up bumps MUCH better. No more jarring feedback that the OEM front suspension gave you. The front is very nice where it is for now but I will play with the compression/rebound and preload as I ride the bike a bit more. Rebound and compression have 12 out of 20 clicks of adjustment. No additional preload added from 0 turns from factory,
The rear shocks I have set with 2.5 turns of preload and the rebound at 1.5 on each shock. Again very smooth but incredibly stable. I was amazed at the change even a half click on the rebound will make. At the softest rebound setting of 1 which is factory there was bouncing over washboard type bumps but at 1.5 it smoothed out and stable. I did not want to increase ride height and the 12" shocks I have 2.7 inches of travel. With sag set at 2.5 preload I have only bottomed out on one severe bump that had same effect on all my bikes I have ridden over it. Nasty bump....
My final thoughts are I am very happy with the Bitubo setup. I think the majority of the top tier suspensions will have similar results. I did not get the Bitubo setup because of pricing but I think it is noteworthy that total delivered cost was $1180.
