Help kahuna heated grips
Old Apr 9, 2022 | 10:56 AM
Ssitruc's Avatar
Ssitruc
Yes, for the power... you can't plug the power wires from the grip in to it with the "cap" on/in it also.
Old Apr 9, 2022 | 11:01 AM
cfiegehen's Avatar
cfiegehen
Thanks for the info but they are the same connector. Both male
Old Apr 9, 2022 | 11:12 AM
Ssitruc's Avatar
Ssitruc
From the grips there should be 2 connectors, 1 male & 1 female. #1 below with the Red & Black wire is female and #3 from the above drawing (Black and Violet wires) should plug into that... #2 below is male with black and white wires should plug into #1 from the above drawing that also has Black and White wires.
In the drawings supplied above #1 is a female, and #3 is a male once you get the protective cap/plug off of it, if somebody hadn't already removed it.
View from standing in front of the bike...
Bike has a Female connector on the left (throttle side) with black and white wires (#1 in drawing). Grips have a Male connector with black and white wires (#2 in picture)... plug them together, that is what ties your right grip to your left grip, called the "interconnect" wire (to get the power from the clutch side grip to the throttle side grip).
Bike has a Male connector on the right (clutch side) black and violet wires (BK & V/BE actually) thats connector (#3 in drawing). Grips have a Female connector with a red and black wire (#1 in picture)... plug them together, that gets the power from the bike to the grips...
Old Apr 9, 2022 | 06:10 PM
Qdraw's Avatar
Qdraw
Originally Posted by cfiegehen
So I take the false plug out and plug into #3
You got it. Just did this same install with some new handle bars. Once you have the throttle side jumpered to the left hand, the existing plug routes to #3 for power. Once that dust cover is removed of course! Lol . Just did my test ride with mine, Love Them!
Old Apr 9, 2022 | 06:17 PM
cfiegehen's Avatar
cfiegehen
Thank you very much for the info. I wonder if I was just doing wrong. I thought both #1 and #3 were make ends
Old Apr 10, 2022 | 10:18 AM
Ssitruc's Avatar
Ssitruc
After you do it once, it get so much easier
Old Apr 10, 2022 | 12:01 PM
cfiegehen's Avatar
cfiegehen
I want to thank everybody so much for the time writing the responses I found that silly little plug and it works fantastic.
yay
ridingout
Mar 23, 2022 03:37 PM
whocares
2014-2024 Touring Models
Aug 2, 2015 02:52 PM
gdbice
Jul 31, 2012 01:23 PM
VINNIE JAMES
Apr 3, 2011 01:06 PM
kent the swede
Jan 24, 2009 10:17 AM
