Garage door opener
Old Apr 18, 2022 | 09:15 AM
adam072987's Avatar
adam072987
Originally Posted by SoCalHarley
I have used the Harley garage door opener for years and have it on all of my motorcycles. A simple toggle of the hi/lo beam and the door opens. The transmitter has amazing range. Install is very easy.
HD and Geezer Glide state their openers done work with MyQ Security 2.0. If it wasnt for the cost Id buy them just to see if I can get them to work.
Old Apr 18, 2022 | 09:17 AM
adam072987's Avatar
adam072987
Originally Posted by Ssitruc
I have a garage door opener that has the MyQ Security stuff, and app... I still use all my previous openers. It was like any other new opener, fun to figure out how to program the existing remotes... I have a "Home Link" kinda like you linked (but not that brand, just Home Link) that I added years ago in my truck, and a Mo-door on the bike. They all work with it. I don't use the MyQ app though, because I brought the garage door opener into my home security app, so everything is all in one app instead of three. But even still, I stayed with a push button on the bike... rather than digging my phone out to push a button on it.
The nice thing about the HomeLink kit, is no batteries to replace, if it will fit behind in the space in the fairing.
I have home link on my truck as well that I just got set up. Id hope it would work with the more slim lined options but without knowing for sure I dont want to waste the money.
Old Apr 18, 2022 | 09:22 AM
adam072987's Avatar
adam072987
I have a gate operated by a keypad or a remote... my cars each have a remote clipped to the visor..
Since I have three bikes, I keep one small, keychain-sized remote with the bike keys... I grab a key and then throw the small remote in a pocket..
If I had only one bike, doubt I would attach the remote to the bike... it's too easy to just put it in a pocket...
Granted, depending on weather and riding gear, sometimes I'll have to stop at the gate and take 20 seconds to remove a thick glove, or search through thick clothes for the button to push on the remote, but it's not really an inconvenience...
Id prefer not to do permanent mod to the bike unless I cant find a better option I like.
Originally I got into this because Id come home at 3a and didn't want to be "that guy" so Id try to open the door, cut the engine and coast into my garage however my current driveway has a pretty good slope to it so I cant just coast in and If I stop and then open it Ill make even more noise.
Old Apr 18, 2022 | 09:37 AM
SoCalHarley's Avatar
SoCalHarley
The Harley remote system has a separate transmitter and receiver. The receiver has a two wire output that wires directly to the garage door opener where the wired button goes to. It is independent of the remote system used by the garage door opener so I'm not sure why.it would not work.
TexasMotorcycleRider's Avatar
I would def do somehting like this but I dont trust it not coming off/getting stolen when its parked because people are ********
I have have a Sena Freewire and a Garage Door opener in there since 2014.....no problems.
Old Apr 18, 2022 | 09:43 AM
RANGER73's Avatar
RANGER73
I've got a tank bib with a pouch. I took the push button opener, soldered a wire to the contact
and put a button with a weatherproof cap through the side of the pouch on the left clutch side.
Works great.
Old Apr 18, 2022 | 09:58 AM
joe.1955's Avatar
joe.1955
https://www.creativeaccesssolutions....dule_p_12.html
use this device with the HD opener and MyQ. I had to add it to mine when my previous opener motor failed.
Old Apr 18, 2022 | 10:39 AM
adam072987's Avatar
adam072987
Perfect! Not sure if I will go with this exact one or get the universal and get a Geezer Glide switch but I have been scowering garage door threads for years then found the geezer glide and thought my problem was solved until I bought a new home and was SOL again. Thanks for the info!
Old Apr 18, 2022 | 01:04 PM
SoCalHarley
That device goes between the HD Receiver and your garage door opener 2.0. If you use the HD transmitter with the HD receiver they communicate directly. I though you were looking for a clean transmitter solution. Why would you want to use your existing garage door opener and not the HD transmitter that uses the HI/LO beam switch. Just curious...
Old Apr 18, 2022 | 01:14 PM
Nbdzhro's Avatar
Nbdzhro
Check this out...
https://rogersunlimitedinc.square.site/
