Quickly changing shocks sag between 1 and 2 up
When I arrive at my destination, I will not have all the crap with me for riding, so I would like to setup my sag back to just me without having to measure it.
Is there a way? I know someone mentioned zip ties before? How?
I was thinking using some wooden coffee stirs and cut them measuring from the bottom of the spring to the edge of the shock? Have a set for each setting?
This is for Legends shocks.
Thank you in advance!
ETA: Nevermind, I found my answer that I should look for before posting
"For the best ride quality, you will want to adjust the Sag/Preload anytime you add/takeaway weight from the bike.
If you sometimes ride two-up, the best practice is to first set your sag with just your weight on the bike. Once you have the sag set for your weight solo, have your passenger sit on the bike, and re-adjust to once again achieve the target eye-to-eye measurement (11.5", 12", or 13") as applicable to the shock you have. When adding preload to the springs to account for the added weight of your passenger, count the turns required to achieve the target eye-to-eye measurement. For example, if you have 13" shocks, and you have the sag set at 1" for your weight solo on the bike (12" eye to eye measurement), and your passenger then sits on the bike, compressing the suspension to an 11" eye to eye length, increase the preload (tighten the springs) to once again achieve the target measurement of 12" eye to eye with both of you on the bike. When readjusting to account for your passengers weight, use the white "Legend" logo on the springs as a reference to count how many turns were required to once again achieve the 12" eye to eye length with your passenger's weight added the bike. Make a mental note of how many turns were required, and then the next time you ride solo, take the same amount of turns back out of the springs, and the sag will be set correctly for you by yourself."
That said I'm really hoping for new touring bikes to have electronic/automatic sag adjustment like the Pan America has. That would make me really tempted to trade up.
For 80 lbs I'd go one turn and call it good, but YMMV.
