2011 flhp small oil leak
Old May 5, 2022 | 07:44 AM
98glider's Avatar
98glider
Default 2011 flhp small oil leak
I have some oil leaking around the oil filter. I am changing the oil soon and was wondering what are the chances that the filter gasket is the problem any other areas that I should look at. I have a rag under the oil filter where it screws in and all good. Cases look dry where the oil cooler is hoses look good. It just seems under the filter but I was wondering if there is any other ares to look at. Thanks
Old May 5, 2022 | 07:49 AM
Jackie Paper's Avatar
Jackie Paper
Filter. Tighten it to instructions on box with a cup tool.
Old May 5, 2022 | 10:33 AM
98glider's Avatar
98glider
I would not think that’s it, I will see when I take it off. Nothing is never that easy
Old May 5, 2022 | 08:13 PM
Budda109's Avatar
Budda109
Stater rubber groumt plug. Common problem, Clean with brake cleaner. Stretch with forceps apply black RTV let dry
Old May 6, 2022 | 04:15 AM
98glider's Avatar
98glider
Stator plug looks good. It is inside by the oil filter
Old May 6, 2022 | 05:27 AM
NELS's Avatar
NELS
I had the adapter the filter screws onto loosen up causing a leak. Sure am glad it didn't fall off riding. Screwed it back in using red locktite
Old May 7, 2022 | 06:44 AM
Drat's Avatar
Drat
Make sure that the adapter is completely tight. That would be the center threaded piece that your filter screws on. It does loosen up and will leak around the filter gasket as the filter will fibrate loose. Only takes a second to check and tighten when you drop that filter. It takes a 7/16ths hex or you can use a 1/4 bolt head in a pinch (I posted this back in 2014) Hope it helps
98glider
Sep 17, 2024 10:56 AM
cmass
Aug 11, 2015 09:15 PM
shovel t
Aug 14, 2012 11:18 AM
LDR
Aug 8, 2012 08:59 PM
joker66
Oil Archive (no new posts)
Dec 28, 2011 03:45 PM
