Light
Old Jun 11, 2022 | 07:17 PM
Longpockets's Avatar
Longpockets
Default Light
I have a 2012 street glide and the 6 gear indicator light not coming on in 6 gear could anyone help?
Old Jun 11, 2022 | 09:31 PM
NODYNA's Avatar
NODYNA
Could be burnt out bulb or led, bad circuit board wiring issue. Check for codes. If none you'll have to trouble shoot it with the wiring diagrams.
Old Jun 12, 2022 | 10:23 AM
lefty33's Avatar
lefty33
Do you have any other issues/irregularities? I had this issue of the 6th gear indicator light not coming on with my previous 2012 UC. Other issue at the same time was it won't start in gear (with the clutch pulled in). Kick it into neutral and started fine. I had a b1154 (clutch switch input short to ground) error code. I tried cleaning it but it didn't change. Replaced the clutch lockout switch and it resolved both problems.
Old Jun 12, 2022 | 10:39 AM
Ultra103's Avatar
Ultra103
If you have an FP3 tuner, call V&H customer service to see if they can fix it. There are a few little glitches that they can fix.
Old Jun 12, 2022 | 12:41 PM
woodthumb2's Avatar
woodthumb2
yep lefty.... usually is linked to something else... cruise ? high idle ? speedo working ? that all happened to me when my speed sensor burped on a long cross country ride..... code thru and dealer said might not happen again after clearing and resatrting..... who knows ..?? it hasnt.
glider1993
May 20, 2020 07:21 PM
soft 02
Aug 6, 2013 01:31 PM
soft 02
Dec 16, 2010 07:59 PM
anv1862
Oct 14, 2010 03:17 PM
powaypete
Aug 15, 2009 09:14 PM
