Primary oil level
Old Jul 24, 2022 | 08:13 PM
cncmike's Avatar
cncmike
Originally Posted by glasspilot
I know this is old school stuff. But I love how we're supposed to have the bike Upright for Pri and Tranny oil checks, but we only have a side/kick/"jiffy" stand. (No center stand) I guess they expect you to have a friend around to help.
Yes, I have a lift but I hate wasting 30 minutes putting my bike on the lift JUST to check oil. But that's what I do when I check those levels. (I usually have other things to do when I use the lift so it's not a complete waste)
I'll get off my soapbox now!
Only the primary needs to be checked upright. Which is usually only when you are changing it. The oil dipstick has marks for upright and sidestand. The trans isn't that critical. If I see anything on the dipstick I'm satisfied.
Old Jul 24, 2022 | 08:28 PM
caulk04's Avatar
caulk04
Originally Posted by decencyxdefied
I think every other image I've seen states the level just a touch higher at the edge of the clutch spring, which has been my custom.
Old Jul 25, 2022 | 10:27 AM
jp0469's Avatar
jp0469
Same here. I check it to this spot because there is a little lip right there that can easily be spotted with a flashlight and small screwdriver. I bring it up until I can see the screwdriver just breaking the surface tension of the lubricant while resting right on that lip.
Old Jul 25, 2022 | 10:39 AM
perki48's Avatar
perki48
Here is proper level.
Old Jul 25, 2022 | 10:44 AM
lp's Avatar
lp
Weird. Back in the day before the manuals started stating just pour in "X amount of Ounces", it stated to fill so the oil is just touching the diaphragm spring... which looks to be the thing in orange....
Old Jul 25, 2022 | 10:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I think you are off by .00001"
Old Jul 25, 2022 | 11:07 AM
jp0469's Avatar
jp0469
Not really though. The entire gray area in that graphic is the diaphragm spring so just touching it would be where my red arrow is.
Old Jul 25, 2022 | 12:42 PM
98glider's Avatar
98glider
In my 1998 manual for my superglide has a diagram like that but in my 2011 manual for my road king does not have a picture illustration just ounces
Old Jul 25, 2022 | 12:56 PM
lp's Avatar
lp
That's where I usually put it as well, but look at the Pic. It's pointing to "Even with the clutch opening"... little arrow, where I drew the orange line.
That's why I said it's "Weird"... That's a huge range. Basically anywhere as long as oil is not dripping out.
BTW, Need to move that Red arrow up some so it's touching the Diaphragm spring and not the outer clutch hub.
Old Jul 25, 2022 | 01:15 PM
Taxgod4u's Avatar
Taxgod4u
why are we having winter threads during riding season? Dump some slippery stuff in and ride!
