New clutch not releasing normal?
Old Jul 23, 2022 | 08:40 PM
Wayne Hand's Avatar
Wayne Hand
Default New clutch not releasing normal?
Hey guys I just put a new Barnett extra plate clutch in my 16 RGS when I had to replace the transmission and now it doesn't fully release when I stop. I can hold it still with the brakes but it also makes it hard to find neutral. Tonight I'm in my first longish ride with the new clutch and transmission and the transmission is generating more heat than it should. I used the standard HD fluid that you can use in the motor tranny and primary. I also soaked the clutch plates in the fluid overnight before installing them. Any ideas? I damned sure don't want to have to pull that thing again
Old Jul 23, 2022 | 08:44 PM
Taxgod4u's Avatar
Taxgod4u
Did you remove the two spacers from the back of the basket befor puttign in the new disks? Mine wanted to stay on the bike after all teh disks were removed so I had to remove.
Old Jul 23, 2022 | 08:52 PM
Wayne Hand's Avatar
Wayne Hand
Yes sir I did. Mine stuck too, had to get them with a pick
Old Jul 23, 2022 | 11:34 PM
Wayne Hand's Avatar
Wayne Hand
BTW when I say the tranny is hotter than it should be I mean it's hotter than the exhaust is
Old Jul 24, 2022 | 01:13 AM
Musician's Avatar
Musician
Wayne, sorry I can't offer any real help here. I installed that Barnett Kevlar extra plate kit in my '08 FLHT. Wee bit touchy getting the release dialed in where I like it, But I did finally get there. Minimal clunk going into first, shifts easy, neutral usually real easy to get. Did the same procedures you did, but the Barnett instructions suggested using ATF instead of the usual oil.
Old Jul 24, 2022 | 08:17 AM
Wayne Hand's Avatar
Wayne Hand
I been thinking about it this morning and it hit me that when I was putting it back together the clutch rod (I guess that's what you call it) was a little stiff to get that end plate on. I had to get one edge of the snap ring started then push the other side down to get it in. Is this creating to much tension and keeping the clutch just a bit engaged? I don't see where that would cause unusual transmission heat though
D J Von Zell
Milwaukee Eight (M8)
Jun 29, 2019 11:07 AM
RKCButcher
Mar 12, 2018 10:23 AM
AdrianVall
Sep 4, 2014 02:46 PM
Velocity1
Jul 28, 2013 08:35 AM
vtlkmonster
Jun 19, 2013 12:41 PM
