Top end chatter
Old Jul 27, 2022 | 07:39 PM
Cruisineasy's Avatar
Cruisineasy
Default Top end chatter
I have a '14 SG. I have been getting a light top end chatter at about 2000 RPM. Doesn't do it all the time. When I get in my garage to check it out it stops. (Imagine that)
Anyone have any ideas??
Old Jul 27, 2022 | 08:31 PM
JTM65's Avatar
JTM65
On early Twinkies it was often clatter from the valve rocker shafts. I put Rocker Lockers on my 01 RK and it quieted them down completely. My current bike, an 06 SG does not make any noise. Luck of the draw maybe.
JT
Old Jul 27, 2022 | 09:04 PM
lp's Avatar
lp
It very well could be something inside the heads, but just the same, hit that forward engine brace located on the Front cylinder with some WD-40 and see if it goes away... something to try anyway.
Old Jul 27, 2022 | 09:25 PM
Sam2010's Avatar
Sam2010
Could it be spark knock with warmer temperatures?
Old Jul 27, 2022 | 09:44 PM
Cruisineasy
JT
Thanks. I'm going to look into this.
Old Jul 27, 2022 | 09:47 PM
Cruisineasy
That would be great if that's the fix. Gonna take the brace out and clean it up.
Old Jul 28, 2022 | 10:34 AM
RadicalSon's Avatar
RadicalSon
My '15 Ultra has similar clacking. From what I read, JTM65 has nailed it; some do, some don't. I may try rocker lockers this winter.
Old Jul 28, 2022 | 11:28 AM
jp0469's Avatar
jp0469
Downshift. Why are you spending any time at 2000 RPM?
ROCKOUT Rocker Products
Sponsor
Have a look around my website, thousands cured around the world with PATENTED Rockout rocker shaft inserts.
John @ Rockout
__________________
NO, they DON'T all do that!
Also on amazon.com...
Nitrusfix
General Topics/Tech Tips
Sep 17, 2015 10:07 PM
Am4wag
Sep 24, 2014 11:34 AM
rodeking
Jan 1, 2010 11:03 AM
hgarzatx
Exhaust System Topics
Oct 5, 2009 06:37 AM
Milan
Jul 15, 2009 07:10 PM
